Interface Invocation
Diagram Element
Parameter Description
  • Node Name: name of a node.
  • Description: details of a node.
  • Interface Type: Select the type of the interface to be invoked. The options are inner interface and self defined interface. If inner interface is selected, the following two built-in interfaces are available:
    • Record Q&A: This interface used to record the survey ID, question title, user reply intention, original user reply, and other information.
    • Obtain the APIFabric token: This interface is used to obtain the API Fabric token. After a robot successfully invokes this interface, the token is recorded in the cache and can be directly obtained from the cache within the validity period. If the AK/SK is changed, the original cache is not cleared, and this interface fails to be invoked within the cache validity period. To invoke this interface immediately, you can bind the flow to a new robot.
  • Invoked Interface: interface to be invoked. Select an interface added on the Resource Management > Business Interface page.
  • Variable assignment: variable name and variable value. The output parameter returned by the interface is valid only on the current node. If you want to use the value in subsequent flow nodes, define a variable here and assign the value of the output parameter to the variable.
  • Condition branch: condition name and condition expression. Define the branches of the exit of the current diagram element. For example, you can set a branch based on the value of an output parameter. Different subsequent flows can be specified for each branch.
  • Method Invocation: Built-in functions described in Built-in Functions can be used if data processing, such as truncation, length obtaining, conversion, and check, is required by businesses.
Condition Branch Description
Table 1 Condition branch description
Condition Branch
Usage
SYSERROR_INNER
ODFS internal error
Triggered when an unknown error occurs in the ODFS. If no option is selected, the flow goes to the exception handling flow.
SYSERROR_INTERFACE
Interface invocation failure
Triggered when an interface invocation exception occurs. If no option is selected, the flow goes to the exception handling flow.
Using the Diagram Element
Click the diagram element or drag it to the canvas, and select the interface to be invoked. The invoked interface needs to be configured on the Resource > Business Interface page in advance. Alternatively, in the dialog box that is displayed, click Add to add an interface. If you use this diagram element to assign a value, you do not need to select an interface. Instead, you can directly add a cache variable and assign a value to it. In this case, you need to maintain global variables in advance.
Typical Application Scenario
For details about how to use the Interface Invoking diagram element, see Typical Application Scenario. In the typical application scenario of the Rule Validation diagram element, the parameter value assignment function of the Interface Invoking diagram element is used.
