- Getting Started
User Guide
- CEC Operation Guide
Tenant Administrator Guide
- Tenant Space
- Configuring the Employee Center
Enabling Manual Services
- Voice and Video Services
Agent Workbench
- Configuring Call Reasons
- Configuring Rest Reasons
- Configuring Contact Record Data Items
- Configuring the Voice Notification Function
- Configuring the One-Click Bidirectional Call Function
- Configuring Screen Pop-ups
- Configuring Pages
- Configuring Dynamic Data Tables
- Querying Table Data
- Managing the Multimedia Library
- Configuring Identity Authentication Processes
Other Configurations
- Configuring the Fault Prompt Tone
- Configuring Satisfaction Surveys
- Configuring the Customized Tone (Agent Ringback Tone)
- Configuring Page Message Notifications
- Configuring Voice Silent Agents
- Managing Messages
- Viewing Contact Records
- Viewing Bidirectional Call Records
- Configuring the Online Chat Service Time
- Viewing Skill Queue Adjustment Records
- Viewing Identity Authentication Records
- Managing Documents
- Managing Harassment Records
- Configuring Service Guidance
- Configuring SmartCare Integration Information
- Configuring a Mobile Agent
Configuring Multimedia Channels
- Configuring the WeChat Channel
- Configuring the Web Channel
- Configuring the X (Twitter) Channel
- Configuring AICC Information
- Configuring the 5G RCS Channel
- Configuring the Email Channel
- Configuring the LINE Channel
- Configuring the WhatsApp Channel
- Configuring the SMS Channel
- Configuring the Instagram Channel
- Configuring the Telegram Channel
FAQ
- How Do I Set the Click-to-Dial Called Route?
- How Do I Enable the Last Agent Mode?
- How Do I Set Session End Due to No Customer Reply?
- How Do I Set Session Transfer Due to No Agent Reply?
- How Do I Set Session Transfer?
- How Do I Set the Third-Party Authentication Key?
- How Do I Enable Offline Messages?
- How Do I Enable Message Push?
- How Do I Enable the Auto Reply and Non-Workday Reply Functions?
- How Do I Enable Connection to the Intelligent Robot?
- How Do I Enable Connection to the Robot Assistant?
- Creating an App Using a Facebook Developer Account
- How Do I Set Automatic Email Reply?
Robot Management and Configuration Guide
- Getting Started
Configuring an Intelligent Robot
- Overview
- Configuring an Appointment Chatbot (Task-oriented Robot)
- Adding a Q&A-oriented Robot
Other Operations
- Managing Variables
- Maintaining Stored Procedures
- Creating Work Calendar Templates
- Adding Data Tables
- Adding Domains
- Adding Entities
- Adding Sensitive Words
- Adding Knowledge Gray Rules
- Managing Models
- Managing Robot Test Cases
- Reviewing a Historical Message
- Processing a Question Clustering Task
- Setting Intelligent Engine Parameters
- Managing the Call History
- Viewing Flow Analysis
- Checking Flows
- Adding Gray Rules
- Configuring 2D Virtual Humans
- Configuring the SmartCare Intelligent Robot
Reference
Diagram Elements
- Start
- Robot Reply
- Conversation Analysis
- Subflow
- Call Ending
- Switching Between Voice and Video Calls
- Voice Playback
- Voice Playback and Digit Collection
- Language Selection
- Semantic Recognition
- Menu Configuration
- Call Transfer
- Error Count Clearance
- Branch Judgment
- Logic Loop
- Variable Assignment
- Rule Validation V2
- Time Selection
- Interface Invocation
- Data Table
- Stored Procedure
- Information Query
- User Level
- Message Leaving
- SMS
- Satisfaction Configuration
- Key Recognition (Expired and Not Recommended)
- Rule Verification (Expired and Not Recommended)
- Date Processing (Expired and Not Recommended)
- SMS Sending (Expired and Not Recommended)
- JSON Data Invoking (Expired and Not Recommended)
- Composite
- Avatar Reply
- Connection Lines Between Diagram Elements
- Parameters
TUC Interfaces
- /chatbot/rest/tuc/v1/nlp/detectRegularEntity
- /chatbot/rest/tuc/v1/nlp/identify
- /chatbot/rest/tuc/v1/recommendFaq
- /chatbot/rest/tuc/v1/qualityInspection/qiOnline/recognize
- /chatbot/rest/tuc/v1/nlp/feedback
- /chatbot/rest/tuc/v1/nlp/textClassify
- /chatbot/rest/tuc/v1/nlp/detectEntity
- Built-in Functions
Diagram Elements
- Why Do I Need to Configure Stop Words?
- Why Are Some Intentions Matched Despite Low Matching Rates?
- Why TTS Cannot Identify the Date Format?
- How Do I Configure the Scenario Where Multiple Slots Are Filled Repeatedly?
- How Do I Resolve the Problem of Infinite Loop During Interaction Between the IVR and ODFS?
- How Do I Configure the Number of Voice Recognition Errors in a Flow?
- How Do I Configure an Entity That Matches Any Character String?
- What Causes Incorrect ASR?
- How Do I Transfer the Disconnection Reason Code to the Specified Business Interface?
- How Do I Configure the Language Recognition Interface?
- How Do I Configure Dynamic Flow Variables?
- How Do I Use a Rule Corpus?
- How Do I Assign Values to and Use Lists and Objects?
- How Do I Parse Call-associated Data?
- How Do I Press a Key to Collect Digits or Return to the Upper-Level Menu When the Play Voice & Collect Digit Diagram Element Does Not Support the Asterisk (*) Key?
Operator: Configuring a Common IVR
- Introduction to the IVR Flow
- Managing Voice and Video Resources
- Configuring a Common IVR
- Configuring Robot Tracking
- Configuring a Called Route
- Configuring a Flow Track
- Configuring IVR Recording
- Querying Flow Transfer Records
- Typical Configuration Example
Diagram Elements
- Start
- Subflow
- Call Ending
- Voice Playback
- Call Transfer
- Branch Judgment
- Logic Loop
- Data Table
- Stored Procedure
- Time Selection
- Information Query
- User Level
- Message Leaving
- SMS
- Survey
- Call Ending (Expired and Not Recommended)
- Condition Judgment (Expired and Not Recommended)
- Ringing (Expired and Not Recommended)
- Response (Expired and Not Recommended)
- User Level (Expired and Not Recommended)
- Time Selection (Expired and Not Recommended)
- Assignment (Expired and Not Recommended)
- Transfer (Expired and Not Recommended)
- Interface Invocation (Expired and Not Recommended)
- Configuring the Preconfiguration Intelligent Flows
- Large Language Model Service Zone
- Small Language Model Zone
- IVR Journey Analysis
- Monitoring Outbound Call Risks
- Managing Cases
Managing Inspections
- Overview on Inspection Management
- Typical Scenario: Configuring Manual Inspection Tasks
- Managing Manual Inspections
- Typical Scenario: Configuring AI Inspection Tasks
- Managing AI Inspections (Self-Developed)
- Managing the Notification Center
- Managing the Customer Center
Making Intelligent Outbound Calls
- Overview of Outbound Call Tasks
Preparations for Creating Outbound Call Tasks
- Managing Special Dates
- Managing Blocklisted Outbound Numbers
- Defining Business Results
- Defining Outbound Call Data Attributes
- Defining Outbound Call Results
- Creating Outbound Call Templates
- Managing the Special List
- Configuring an Outbound Call File Server
- Importing Mapping Rules
- Managing Task Groups
Managing Outbound Call Tasks
- Creating Common IVR Outbound Call Tasks or Intelligent Robot Outbound Call Tasks
- Creating Predicted Outbound Call Tasks
- Creating Previewed Outbound Call Tasks
- Creating Preempted Outbound Call Tasks
- Creating Fixed Outbound Call Tasks
- Creating Manual Outbound Call Tasks
- Configuring an Outbound Call Task
- Managing Outbound Call Tasks in Batches
- Managing Multimedia Marketing
- Managing Outbound Call Task Reports
- Managing Surveys
- Managing Intelligent Training
- Configuring the Knowledge Base
Configuring Public Resources
- Modifying Policy Information
- Viewing Interconnection Parameters
- Configuring Parameters
- Adding Customer Numbers to the Special List
- Configuring the Channel Special List
- Managing a Certificate
- Configuring Email Special List Rules
- Configuring SMS Special List Rules
- Configuring Resource Dump Tasks
- Managing Menus
- Managing Email Signatures
- Configuring Message Flow Control Rules
- Configuring UC Integration
- Managing Emails
- Configuring External Numbers
- Querying Operation Logs
- Querying Sign-in Logs
- Managing Business Fault Bypass
- Co-browsing
- Social Media Operations
- Performance Management
Agent Guide(AICC)
- Introducing Agent Workbenches
- Switching the Agent Status
- Allowing Browser Pop-up Notifications
- Handling Voice Businesses
- Handling Video Businesses
- Handling Multimedia Chat Businesses
Performing Other Agent Operations
- Configuring the Personal Center
- Querying Historical Contacts
- Viewing Inbound Call Information
- Setting the Handled Number
- Setting Call Reasons
- Setting the Online Chat Service Time
- Configuring Personalized Common Phrases
- Sending Notifications
- Performing Identity Authentication
- Viewing Customer Information
- Creating Harassment Records
- Editing Customer Information
- Querying Sign-In Records
- Performing Screen Recording for Agents
- SmartCare Fault Demarcation
- Intelligent Case Filling
- Creating a Case by One Click
- Searching for Satisfaction Statistics
- Managing Inspection Results
- Typical Scenarios
- Viewing Training Tasks
Intelligent Outbound Call Tasks
Agent Outbound Call Task
- Introduction to the Outbound Call Task of an Agent
- Manually Making an Outbound Call
- Viewing and Executing a Previewed Outbound Call
- Viewing a Predicted Outbound Call
- Viewing a Preempted Outbound Call
- Creating a Reserved Outbound Call Task
- Adding a Customer Number to the Blocklist
- Changing an Outbound Number
- Viewing Outbound Call Results
- Reserved Manual or Automatic Outbound Call
- OpenEye Help Document
- Implementing Intelligent Case Filling
Inspector Guide
- Processing Manual Post-Event Inspections
- AI Inspection
Performing Agent Monitoring and Inspections
- Monitoring Configuration
- Monitoring Management
Report Query
- VDN Traffic Report
- VDN Traffic Report by Access Code
- IVR Traffic Report
- IVR Traffic Report by Access Code
- Skill Queue Traffic Report
- Skill Queue Traffic Report by Access Code
- Traffic Summary Report
- Agent Traffic Report
- Agent Outbound Call Report
- Agent Operation Report
- Abandoned Call in Ringing Report
- Interval-based VDN Traffic Report
- IVR Outbound Call Report
- System Performance Report
- Agent Timesheet Report
- Price Details
Developer Guide
Development Overview
- Development Map
Development Solutions
- Multimedia Channel Access Solution
- Self-Service (IVR) Integration Solution
- Voice and Video Agent Integration Solution
- Multimedia Agent Integration Solution
- Mobile Agent Integration Solution
- Screen Pop-up Integration Solution
- Intelligence Solution
- Operations Monitoring and Report Integration Solution
- Automatic Outbound Call Integration Solution
- CDR Download and Recording Backhaul Integration Solution
- Development Preparations
- Contact Us
- User Access-VoIP Voice and Video Access
User Access-Web Lightweight Client Integration (JS)
- Lightweight Web Chat Control Integration (Token Mode)
- Lightweight Web Chat Control Integration (Authorization Mode)
User Access--Web Client Access (RESTful)
- Overview
- Machine-Machine Interface, AK/SK-based Authentication Interface
- Third-party Request Authentication
- Query Queue Information
- Proactively Poll Information Sent by Agents
- Submit Customer Satisfaction Evaluation Results
- Send Message
- Send Files by Customer
- Receive Document by Customer
- Associate Common Phrases
- Create Click-to-dial Call
- Get Click-to-dial Event
- Check Whether Support Click-to-dial
- Release Click-to-dial Call
- Submit Offline Messages by Customer
- Create an Anonymous Call
- Submit Customer Satisfaction with Robots
Agent Integration-Agent Lightweight Connection Block Integration (JS)
- Overview
- Integration Principles
- Integration Procedure
- Preparations
- Integration Development
- (Optional) Developing Other Functions
- Test and Verification
- Agent Integration--CC-Gateway Development Guide
Agent Integration-OpenEye H5 Softphone Interface Integration
- Change History
- OpenEye H5 Softphone Interface Overview
- OpenEye Installation Guide
- Development Guide to H5 Softphone Integration on the Agent Side
- Voice Call Interfaces
Voice and Video Call Interface Extension
- Voice and Video Calls
Device Management
- getMediaDevices (Obtaining the Device List)
- setMicIndex (Setting the Microphone)
- mediaGetMicIndex (Querying the Microphone in Use)
- setSpeakIndex (Setting the Speaker)
- mediaGetSpeakIndex (Querying the Speaker in Use)
- setMicVol (Setting the Microphone Volume)
- getMicVol (Querying the Current Microphone Volume)
- setSpkVol (Setting the Speaker Volume)
- getSpkVol (Querying the Current Speaker Volume)
- setVideoWindowParam (Setting the Position, Width, and Height of the Video Window)
- setVideoLayoutMode (Setting the Video Window Layout Mode)
- setVideoDisplayMode (Setting the Image Cropping Mode in the Video Window)
- openCamera (Turning on the Camera)
- closeCamera (Turning off the Camera)
- Screen Sharing
- Screenshot
- Screen Recording
- Error Codes
Operation Management - Agent Workbench Integration with Third-Party Web Pages
- Overview
- Scenario 1: Integration by Using a URL (in GET Parameter Transfer Mode)
- Scenario 2: Integration by Using a URL (in POST Parameter Transfer Mode)
Scenario 3: Integration by Using a URL (in Page JavaScript Invocation Mode)
- Overview
- Development Procedure
- Preparation
- Importing AICC.Support.js
- Developing the Function of Registering Listening Events
- Developing the Function of Removing Listening Events
- Developing the Function of Making One-Click Outbound Calls
- Developing the Function of Obtaining the Identity Authentication Result
- Development Example
- Post-development Configuration
Appendix - Process Description
- Overall Working Process
- Process of Registering a Listening Event (addHandler)
- Process of Removing a Listening Event (removeHandler)
- Process of Executing a One-Click Outbound Call (clickToOutbound)
- Process of Executing the Handling Method of a Registered Event
- Process of Executing the One-Click Outbound Call Method
- Process of Obtaining the Identity Authentication Result
- Scenario 4: Integration by Invoking an Enterprise API
- Scenario 5: Integration by Recording Information to the CEC
API Reference
- Interface Overview
- Glossary
- Change History
- Interface Authentication Modes
Call Center Configuration Interface Reference
Agent Management
- Creating a Single Agent Account (agentAccount/create)
- Deleting a Specified Agent Account (agentAccount/delete)
- Modifying Information About an Agent Account (agentAccount/update)
- Querying Agent Account Information (agentAccount/query)
- Binding an Agent to a Skill Queue (addSkillsToAgent)
- Unbinding an Agent from a Skill Queue (releaseAgentBySkillId)
- Querying Agent Information by Skill Queue ID (queryAgentInfoBySkillId)
- Changing the SIP Phone Number Login Password of an Agent (updateSipPhonePassword)
- Querying Softphone Information of All Agents, Excluding Business Accounts (querySysInfo)
- Querying Softphone Information of All Agents, Including Business Accounts (queryAgentInfo)
- Querying the Account Sign-in Result (queryAgentLoginParams)
- Querying Agent Information by Sign-in Account (queryAgentInfoByAccount)
- Deleting Data by Customer Number (cleancustpersonaldata)
Skill Queue Management
- Creating a Skill Queue (createSkill)
- Deleting a Skill Queue (deleteSkill)
- Modifying a Skill Queue (modifySkill)
- Querying Skill Queues (querySkills)
- Obtaining the Total Number of Users in a Configured Skill Queue
- Obtaining the Number of Users in a Skill Queue to Which an Agent Has Signed In
- Obtaining the Skill Queue Information of the Home VDN of an Agent
- Obtaining the Total Number of Users in a Specified Skill Queue
- Querying the Statistics About a Set of Skill Queues
- Querying the IVR Information of the VDN to Which an Agent Belongs
- Querying Information About Agents That Have Signed In to a Skill Queue
- Querying the Details About a Specified Agent
- Querying the Details About All Online Agents That Have Signed In to a Skill Queue
Number Management
- Querying Access Codes (queryAccessCodeList)
- Creating a Binding Relationship Between an Access Code, Skill Queue, and IVR (createCalledRoute)
- Deleting the Binding Relationships Between Access Codes, Skill Queues, and IVR Flows (deleteCalledRoute)
- Modifying a Binding Relationship Between an Access Code, Skill Queue, and IVR (modifyCalledRoute)
- Querying the Binding Relationships Between Access Codes, Skill Queues, and IVR Flows (queryCalledRoute)
- Querying the Home Area of a Number (getPhoneNoRegionInfo)
IVR Flow Management
- Querying All IVR Flows of a Specified Tenant Space (queryIVRFlowList)
- Querying Satisfaction Survey Information (querySatisfactionConfig)
- Querying Satisfaction Survey Results (satisfaction /query)
- Uploading IVR Voice Files (importVoiceFile/upload)
- Uploading a TTS Template for Voice Notifications (createVoiceTemplate)
Agent Management
Agent Workbench Interface Reference
Agent Control
Agent Operation Interfaces: onlineagent
- Signing In
- Forcibly Signing In
- Maintaining the Heartbeat by an Agent
- Sending Notes
- Querying Configured Skill Queues
- Querying Configured Skill Queues of Specified Agents
- Setting Automatic Answering
- Resetting Skill Queues
- Setting Idle
- Setting Busy
- Canceling the Busy State
- Applying for Rest
- Canceling Rest
- Entering the Work State
- Quitting the Work State
- Changing the Password (Extended)
- Setting Whether to Enter the Idle State
- Signing Out
- Forcibly Signing Out
- Forcibly Signing Out with a Cause Code
- Getting Agent Status
- Setting Whether to Answer Inbound Calls
- Signing In to the Platform by an Agent
- Actively Requesting to Update the GUID When the Agent Page Is Refreshed
- Synchronizing the Agent Status and Call Information When the Agent Page Is Refreshed
- Obtaining Token Information
- Customizing Status by an Agent
- Querying Customized Status by an Agent
- Canceling Status Customization by an Agent
Call Control Interfaces: voicecall
- Making a Common Outbound Call
- Making a Previewed Outbound Call
- Answering a Call
- Making an Internal Call
- Asking for Internal Help
- Muting a Call
- Unmuting a Muted Call
- Holding a Call
- Holding a Call
- Unholding a Call
- Transferring a Call
- Canceling Transfer
- Performing Two-Stage Dialing (Extended)
- Making a Three-Party Call
- Disconnecting a Call of a Specified ID
- Dropping a Call
- Releasing a Connection of a Specified Number
- Controlling the Image Display Mode of a Three-Party Video Call
- Requesting a Specified Call
- Picking Up a Call for Other Agents
- Rejecting an Inbound Call
- Taking the Phone Off the Hook
- Rejecting a Call
- Passing Numbers in a Conference
- Answering Calls on a Mobile Phone (login)
- Exiting the Function of Answering Calls on a Mobile Phone (logout)
- Querying Whether a Specified Agent Answers Calls on a Mobile Phone (isOfflineAgent)
Call Data (calldata)
- Querying Call Information
- Querying Call-Associated Data
- Configuring Call-Associated Data (Extended)
- Querying the List of Held Calls
- Querying Call Information Before Answering a Call
- Querying Call Information by Call ID
- Querying Call IDs of a Specified Agent
- Querying the Number of Current Calls of an Agent
- Querying Current Call Statistics Information About an Agent
- Querying the Current Call Statistics of an Agent (Extended)
- Querying Information About Calls Waiting in a Specified Skill Queue
- Querying All Calls Placed on Hold by a Specified Agent
- Agent Event: agentevent
- Multimedia: mediaCall
Agent Conference: agentconf
- Applying for an Agent Conference
- Answering an Agent Conference Call
- Rejecting an Agent Conference Call
- Leaving an Agent Conference
- Releasing an Agent Conference
- Holding a Participant in a Conference
- Unholding a Participant in a Conference
- Applying for Extending a Conference
- Transferring the Chairperson Permission
- Inviting Participants in Batches
- Deleting Participants in Batches
- Modifying Participant Attributes
- Playing an Announcement in an Agent Conference
- Stopping Conference Announcement Playing
- Playing an Announcement in an Agent Conference Channel
- Stopping Announcement Playing in an Agent Conference Channel
- Changing the Number of Conference Participants
- Querying Conference Information in Batches
- Querying an Ongoing Conference ID in the VDN
Agent Bidirectional Calls
- Creating a Bidirectional Call (V1.0.0) (createCall)
- Creating a Bidirectional Call (V3.0.0) (createCall)
- Querying Call History Records (queryCallDetailRecord)
- Querying Call Status (queryCallState)
- Obtaining the Recording File URL (getRecordingAddress)
- Querying Allocated Softphone Numbers (V1.0.0) (queryPhone)
- Querying Allocated Softphone Numbers (V2.0.0) (queryPhone)
- Obtaining the Information About the Destination Device of a Call (getCalledInfo)
- Creating a Voice Outbound Call (V1.0.0) (createVoiceNotification)
- Creating a Voice Outbound Call (V2.0.0) (createVoiceNotification)
- Querying Contact Records (queryUserContactLimit)
- Querying Call Information (queryCallInfoByCallId)
- Sending an ITA Bidirectional Call Result Notification (statusnotify)
- Callback Interface
Voice Recognition Result Subscription Interfaces
- Subscription
- Subscription Modification
- Unsubscription
- Handshake
- Handshake (Extended)
- Recognition Result Notification
Error Code Definition
- Error Codes Returned by the CC-Gateway
- Common Voice Recognition Result Subscription Interface Error Codes
- Common Error Codes Returned by the CTI Platform
- VDN Configuration Interface Error Codes Returned by the CTI Platform
- System Configuration Interface Error Codes Returned by the CTI Platform
- Error Code Returned by UAP
- Role Permission Bit Description
- App Personal Settings
Appendix
Events
- Events Related to Agent State
Audio and Video Call Event
- Entering the Talking State
- Customer Ringing
- Holding Success
- Entering Three-Party Conversation Successfully
- Making an Outgoing Call Unsuccessfully
- Outbound Call Failure Cause Detected
- Making an Internal Call Unsuccessfully
- No Answer from an Agent for a Long Time
- Agent Exiting a Call
- User Exiting a Call
- Automatically Answering a Call
- Notifying the Agent of an Inbound Call
- Connection Failure
- Consultation Failure
- Notifying the Transfer Success Result
- Returning from IVR
- Switching Between Audio and Video Calls
- Media Capability Check
- Inbound Call Notification
- Events Related to Outgoing Call
- Recording Events
- Events Related to Voice Playback by Quality Checks
- Events Related to Real-time Quality Control
- Events Related to Physical Phone
- Other Agent-Related Events
- Events Related to Multimedia
- Agent Conference Event
- Events Related to Disaster Recovery
- Phone Linkage Events
- Error Codes
- Agent Status
- Call Type
- Device Type
- Interface Parameters
Events
Agent Control
Telemarketing Outbound Call Interface Reference
Outbound Campaign Management Interfaces
- Adding an Outbound Campaign (V1)
- Adding an Outbound Campaign (V2)
- Modifying an Outbound Campaign (V1)
- Modifying an Outbound Campaign (V2)
- Deleting an Outbound Campaign
- Querying Details About an Outbound Campaign
- Querying All Outbound Campaigns
- Suspending an Outbound Campaign
- Resuming an Outbound Campaign
- Setting the Retry Policy of an Outbound Campaign
- Querying the Retry Policy of an Outbound Campaign
- Adding the Definition of an Outbound Call Business Result
- Querying the Definitions of Outbound Call Business Results
- Collecting Outbound Call Exception Statistics
- Adding Calling Numbers
- Deleting Calling Numbers
- Interfaces for Managing Outbound Campaign Holidays
- Interface for Outbound Blacklist Management
Outbound Call Data Interfaces
- Adding Outbound Numbers
- Adding Outbound Numbers (V2)
- Deleting an Outbound Number
- Adding Number Types
- Querying Number Types
- Querying Outbound Numbers
- Collecting Outbound Call Statistics on the Current Day
- Importing an Outbound Call Data File from the Server
- Querying Outbound Call Data File Import Results
- Outbound Result Interface
- Outbound Callback
- Business Result Writeback
- File Server Management Interfaces
- Outbound Call External Result Definition Interfaces
- Querying Interface Invocation Records
- Survey Interface Reference
- iKBS Interface Reference
Chatbot Management Interface Reference
- Overview
- Domain Query Interface
- Dialog ID Binding Interfaces
- Flow Query Interface
- Dialog Interfaces
- Dialog Interfaces (V2)
- Interaction Record Query Interface
- Session Record Query Interface
FAQ Configuration Interface
- FAQ Group Query Interface
- FAQ Group Creation Interface
- FAQ Group Modification Interface
- FAQ Group Deletion Interface
- FAQ Group Status Change Interface
- Q&A Query Interface
- Q&A Creation Interface
- FAQ Modification Interface
- Q&A Deletion Interface
- Specific FAQ Group Test Interface
- FAQ Group Test and Activation Interface
- Intention List Query Interface
- Dedicated Interfaces for Silent Agents
- Interface for Pushing Packet Capture Recording Request Results
- Spelling Check Interface
- Specifications of the Interface for Connecting the ODFS to a Third-Party Robot System
- Statistics Report
- Querying the Offline Analysis of Outbound Call Failure Causes
- Intelligent Case Interface
- Interface for Querying the Recordings of Calls Transferred to a Third Party
- Semantic Recognition Interface
- GTS RPA Integration Interfaces
- Interface for Generating TTS Voices Based on Texts
- Offline Conversion Callback Interface
- Health Check Interface
Web Client Access Interface Reference
- Performing Third-Party Request Authentication (applyToken)
- Querying Queuing Information (queryQueueInfo)
- Proactively Polling Messages Sent by Agents (poll)
- Submitting the Customer Satisfaction Evaluation Result (saveSatisfaction)
- Sending a Message (send)
- Sending a File by a Customer (uploadFileStream)
- Receiving a File by a Customer (downloadFileStream)
- Associating Common Phrases Based on the Customer Input (queryPhraseByKeyword)
- Checking Whether the Current Tenant Space Supports the Click-to-dial Function (checkClickToCallSupport)
- Creating a Click-to-Dial Call (createClickToCall)
- Obtaining a Click-to-Dial Event (getClickToCallEvents)
- Releasing a Click-to-Dial Call (dropClickToCall)
- Creating an Anonymous Call (createcall)
- Submitting a Message by a Customer (doLeaveMessage)
- Submitting the Chatbot Satisfaction Evaluation Result (feedbacksatisfaction)
- Querying Historical Messages (queryHistoryChatMessage)
- Discarding an Email (chat_dropMail)
- Sending an MT WhatsApp Message (sendWhatsappMessage)
- Querying Information About the Current Chat on the Online Chat Workbench (getUserInfoBycallId)
- Querying the Satisfaction Survey Configuration (getSatisfactionSurveyMode)
Inspection, Monitoring, and Statistics Collection Interface Reference
Real-time Inspection: qualitycontrol
- Inserting
- Listening
- Intercepting
- Canceling Listening and Inserting
- Indicating an Agent in Busy State Forcibly
- Indicating an Agent in Idle State Forcibly
- Releasing a Call Forcibly
- Adjusting the Skill Queue of a Specified Agent
- Switching Between Listening and Inserting
- Forcing an Agent to Rest
- Requesting for Whispering
- Stopping Whispering
- Switching Among Whispering, Listening, and Barging
Intelligent Quality Check
scoresetting
- POST /CCSQM/rest/ccisqm/v1/appraisescore/createAppraiseScore
- POST /CCSQM/rest/ccisqm/v1/appraisescore/applyAppraiseScore
- POST /CCSQM/rest/ccisqm/v1/appraisescore/removeAppraiseScore
- POST /CCSQM/rest/ccisqm/v1/appraisescore/queryAppraiseScore
- POST /CCSQM/rest/ccisqm/v1/appraisescore/modifyAppraiseScore
sentencemanagement
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/createSentenceCategory
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/moveSentenceToCategory
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/deleteSentence
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/querySentence
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/querySentenceByCategoryId
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/updateSentence
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/updateSentenceCategory
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/deleteSentenceCategory
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/querySentenceCategory
sensitiveWordManage
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/deleteSensitiveWord
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/querySensitiveWordList
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/deleteSensitiveCategory
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/updateSensitiveWord
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/querySensitiveCategoryList
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/querySensitiveWordsByCategoryId
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/createSensitiveCategory
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/moveSensitiveWordToCategory
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/createSensitiveWord
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/updateSensitiveCategory
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/querySensitiveWordDetail
- conversationspecific
- SemanticKeywordTraining
- conversationflow
- conversationrules
interposalrules
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/getInterposalRuleById
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/queryInterposalRules
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/deleteInterposalRule
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/addInterposalRule
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/updateInterposalRule
- Common Parameter Structure
- silencerule
- speedrule
scenariomanage
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/deleteScenario
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/updateScenarioStatus
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/createScenario
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/queryScenario
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/queryAllScenario
- qualitycheckmanage
regularQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/addQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/beginQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/updateQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/deleteQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/queryQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/stopQualityTask
qualitytask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/deleteQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/updateQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/terminateQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/takeEffectQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/queryQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/appointQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/createQualityTask
- qualitytaskdetail
qualityitem
- POST /CCSQM/rest/ccisqm/v1/qualityitem/reassginQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualityitem/modifyQualityItemResult
- POST /CCSQM/rest/ccisqm/v1/qualityitem/appealItem
- POST /CCSQM/rest/ccisqm/v1/qualityitem/queryQualityItem
- POST /CCSQM/rest/ccisqm/v1/qualityitem/queryQualityItemDetail
- POST /CCSQM/rest/ccisqm/v1/qualityitem/queryQualityItemResult
- POST /CCSQM/rest/ccisqm/v1/qualityitem/queryQualityHistory
- asrtrans
scoresetting
Monitoring and Statistics Collection
Real-Time Data Query
Real-Time Interfaces for VDNs
- Querying Information About System Access Codes in a Specified VDN
- Querying Agent Rest Information in a Specified VDN
- Querying Agent Phone Numbers in a Specified VDN
- Querying Information About All Agents in a Specified VDN
- Querying Information About the Current Status of All Agents in a Specified VDN
- Querying Information About Static Configurations of All Agents in a Specified VDN
- Querying IVR Status Details in a Specified VDN
- Querying Information About IVR Flow Access Codes in a Specified VDN
- Querying Information about Each Skill Queue in a Specified VDN
- Querying All Rest Reason Codes in a Specific VDN
- Querying Information About Calls of a Specified Access Code
- Querying Call Information in a Specified VDN
- (V2) Querying Call Information in a Specified VDN
- Querying the Call track Data in a Specific VDN
- Querying Static Configuration Information About All Agents in a Specified VDN (Not Supported by CTI 3.6)
- Querying Information About All Agents in a Specified VDN (Not Supported by CTI 3.6)
- Obtaining Real-Time Monitoring Indicators by VDN
Real-Time Interfaces for Skill Queues
- Querying Signed-in Agents in Skill Queues in Batches
- Querying Extended Information About Skill Queues in Batches
- Querying Call Statistics of Skill Queues in the Current 5 Minutes in Batches
- Querying Information About Status of a Specified Skill Queue
- Querying Information About Skill Queue Configurations in Batches
- Querying Statistics Details of Skill Queues in Batches
- Querying All Calls Queuing in a Skill Queue in Batches
- Querying the Number of Calls that Each Queue Answers from Other Queues in Batches When Calls are Queuing in Multiple Skill Queues
- Querying the Number of Agents in Each State in a Skill Group
- Querying Details About Signed-in Agents in a Skill Queue
- Querying Service Quality for Skill Queues in Batches
- Obtaining Real-Time Monitoring Indicators by Skill Queue
Real-Time Interfaces for Agents
- Querying Skill Queues to Which Agents Sign In in Batches
- Querying Agent Information in Batches
- Querying the Current Call ID of a Specified Agent
- Querying Call Information About All Agents in Batches
- Querying Private Calls of a Specified Agent
- Querying the Number of Agents in the Agent State in batches
- Querying Details of a Specified Agent
- Checking Whether an Agent Is Processing a Call
- Querying System Status by Agent
- Obtaining Real-Time Monitoring Indicators by Agent
- Obtaining Agent Operation Details
- Querying Agent Information by Agent Status in Pagination Mode
- Real-Time Interfaces for Call Details
Historical Data Query
- Obtaining Historical Monitoring Indicators by VDN
- Querying Information About Missed Calls in a Specified VDN
- Obtaining Historical IVR Monitoring Indicators
- Obtaining Historical Monitoring Indicators by Skill
- Obtaining Historical Monitoring Indicators by Agent
- Obtaining Historical Monitoring Indicators in a Specified Time Range by Skill
- Obtaining Historical Monitoring Indicators in a Specified Month Range by Skill
- Obtaining Historical Monitoring Indicators in a Specified Time Range by Agent
- Obtaining Historical Monitoring Indicators in Specified Month by Agent
- Collecting Statistics on Result Sets in Daily Settlement Table for Inbound Calls
- Collecting Statistics on Result Sets in Daily Settlement Table for Outbound Calls
Configuration Data Query
- Querying Information about All VDNs in a Specified Call Center
- Querying Information About All Agents by VDN ID
- Obtaining All Called Routes in a VDN
- Querying Information About All Agents by Tenant Space ID
- Querying Skill Groups in a Specified VDN
- Querying Information About All Tenants Accessible to an Access User
Inspection Relationship Maintenance Interfaces
- Querying a User Group Member
- Deleting Members from a Group in Batches
- Adding Members to a Group in Batches
- Querying All User Groups
- Adding a User Group
- Deleting a User Group
- Updating User Group Information
- Setting Inspection Relationships
- Deleting Configured Inspection Relationships
- Adding an Agent to a User Group
- Updating Agent Names
- Querying Outbound Call Task Lists
Interfaces for Querying System Indicators
- Querying UAP Performance Information
- Querying Key Information About Control Blocks
- Querying the Registration Status of a Terminal
- Interface for Querying UAP Performance Indicator Statistics
- Interface for Querying UAP Terminal Statistics
- Interface for Querying CTI System Indicators
- Querying the Time of the CTI Platform Server
- Querying the Current License Usage in the System
- Checking Cluster Health Status
Appendix
- Indicator Code Reference
- Error Code Reference
- CTI Platform Agent Status Code Reference
- Description of Call Media Types
- Description of Call Submedia Types
- Description of Call Types
- Description of Agent Types
- Call Features
- Reasons for Leaving the Device of the Call
- Cause Code
- Device Types
- Agent Operation Types
- Interfaces of Earlier Versions (Versions Earlier Than 8.13.0)
Recording and CDR Interface Reference
- Recording
CDR Download and Recording Playback and Download
Data Access Interface
- Obtaining a Recording Download and Playback URL
- Generating CDRs and Recording Indexes
- Downloading CDRs and Recording Indexes
- Downloading a Recording File
- Downloading a Recording File (Extended)
- Generating Indexes of Agent Operation Details
- Downloading Indexes of Agent Operation Details
- Requesting to Play Back a Recording File
- Playing Back a Recording File
- Downloading an Intelligent IVR Recording File
- Downloading IVR Voice Messages
- Downloading a Recording File as a Third Party
- Uploading a File as a Third Party
- Generating a File Hash Value as a Third Party
- Deleting an Uploaded File as a Third Party
- Index File Definition
- Reference Description
- Voice Notification Interface Reference
- OMA Interface Reference
- DataProcess Interface Reference
- Other Interfaces Reference
- FAQs
Call Transfer
This diagram element is used to transfer a call to an IVR flow (an existing key pressing flow) or an agent.
Diagram Element
Parameter Description
- Node Name: name of a node.
- Description: details of a node.
- Transfer Type: The options are as follows:
- Skill Queue (Route Extension Code) (1)
- IVR (2)
- Skill Queue (Name) (3)
- Transfer to Skill Queue (Customized Route) (10)
- Agent (4)
- Third-party number (5)
- Online Digital Assistant (6)
- Audio and video familiar customers (9)
- Multimedia familiar customer (7)
- Skill queue (MAgent) (8)
- Familiar customer message (31)
- Skill queue message (name or access code) (32)
- Message to an Agent (33)
- Route Value: Select a value from the drop-down list box.
- If Transfer Type is set to Skill Queue (Route Extension Code), set this parameter to the extension code for transferring to a skill queue. For this configuration, you need to ensure that the manual flow and the current flow are under the same system access code. The call is transferred to the manual skill queue through the extension code configured on the Called Party page.
Figure 2 Extension Code
- If Transfer Type is set to IVR, set this parameter to the IVR flow access code.
The following figure shows the IVR flow access code in the AICC integrated deployment mode.
- If Transfer Type is set to Skill Queue (Name), set Route Value to the name of the skill queue where the agent to whom the call is transferred resides, for example, Agent Group 1. You can choose Configuration Center > Employee Center > Skill to view the skill queue name.
- If Transfer Type is set to Transfer to Skill Queue (Customized Route), set the corresponding routing policy.
- If Transfer Type is set to Agent, set this parameter to the platform agent ID of the agent to whom the call is transferred.
- If Transfer Type is set to Third-party number, set this parameter to the third-party number.
- If Transfer Type is set to Online Digital Assistant, set this parameter to the flow route code agreed with the third-party intelligent system.
- If Transfer Type is set to Audio and video familiar customers, you do not need to set the route value, but you need to configure the call-associated data by referring to Table 3.
- If Transfer Type is set to Multimedia familiar customer, you do not need to set the route value, but you need to configure the call-associated data by referring to Table 3.
- If Transfer Type is set to Skill queue (MAgent), set this parameter to the platform agent ID or variable corresponding to the agent to whom the call is transferred.
- If Transfer Type is set to Familiar customer message, you do not need to set the route value, but you need to configure the call-associated data by referring to Table 3.
- If Transfer Type is set to Skill queue message (name or access code), set this parameter to the name or access code of the skill queue where the agent to whom the call is transferred resides.
- If Transfer Type is set to Message to an Agent, set this parameter to the platform agent ID or variable corresponding to the agent to whom the call is transferred.
- Routing Policy: This parameter needs to be set only when Transfer Type is set to Transfer to Skill Queue (Customized Route). The options are Percentage and Number segment.
Figure 3 Setting Routing Policy to PercentageFigure 4 Setting Routing Policy to Number segment
- Percentage configuration: When Routing Policy is set to Percentage, you need to configure multiple skill queues and their routing percentages. During call transfer, the system dynamically assigns calls to skill queues based on the percentage configuration.
Table 1 GUI elements for the percentage configuration Element/Component
Type
Value Range
Triggering Event
Remarks
Skill Queue
Drop-down list
Skill queue to which calls are transferred.
All skill queues except multimedia skill queues
Click
- A skill queue cannot be selected repeatedly.
Percentage
Text box
Percentage of calls transferred to a skill queue during transferred-to skill queue assignment.
1 to 100
Enter
The total percentage must be 100.
Button
Delete a percentage setting.
Click
Button
Add a percentage setting.
Click
- Default Skill Queue: When Routing Policy is set to Number segment, you need to select a skill queue as the default skill queue to which calls are transferred when no skill queue is matched based on the number segment matching rule configuration.
- Matching rule: When Routing Policy is set to Number segment, you need to select a matching rule. The options are Prefix and Suffix.
- Number segment matching rule configuration: When Routing Policy is set to Number segment, you can select different skill queues and configure different prefixes or suffixes for them. During call transfer, the system transfers calls whose calling numbers exactly match the configured prefixes or suffixes to the corresponding skill queues.
Table 2 GUI elements for the number segment matching rule configuration Element/Component
Type
Value Range
Triggering Event
Remarks
Skill Queue
Drop-down list
Select
Prefix/Suffix
Text box
Prefix/Suffix used for calling number matching during call transfer to a skill queue.
Button
Delete a number segment matching rule setting.
Click
Button
Add a number segment matching rule setting.
Click
- Associated Data: The call-associated data can be in JSON format (flow variables and global variables are supported). Manually enter a value, or click the edit icon and add information in the Set TransferData dialog box.
Figure 5 Set TransferData (transfer to a skill queue, including manual and multimedia skill queues)Figure 6 Set TransferData (transfer to the last agent, including manual and multimedia agents)Figure 7 Set TransferData (transfer to others)The format of the generated complete JSON data is as follows:
{ "wait": "Y", "isSpecifyAccessCode": "true", "type": "1", "time": "30", "starttime": "" "data": { "serviceId": ${FLOW.test}, "yy": "bbb" }, }
Table 3 Call-associated data parameters Element/Component
Key in JSON Data
Type
Value Range
Triggering Event
Remarks
Queue Queuing
wait
Switch
Whether a call can wait in a skill queue until the session times out when the call is transferred to the skill queue.
- Y
- N
Click
This parameter can be set only when a call is transferred to a skill queue, including manual and multimedia skill queues.
Specified Channel Access Code
isSpecifyAccessCode
Switch
Whether to transfer to the current channel when a call is transferred to the last agent.
- true
- false
Click
This parameter can be set only when a call is transferred to the last agent, including manual and multimedia agents.
Familiar Customer Mode
type
Drop-down list
Mode of selecting the last agent.
1: agent within the specified minutes
2: agent within the specified time range
3: agent on the current day
Select
Transfer Data
data
Table
Call-associated data that needs to be carried during call transfer.
Transfer Parameters
Customized key
Text box
Key in call-associated data.
Enter
- To obtain the customer type field, set the transferred parameter to customerEntityName.
- To use a visualized service guidance flow, set the transferred parameter to serviceRequest.
Value
Text box
Value of the key in call-associated data.
Enter
- Variables can be used, for example, ${FLOW.variable}.
- To obtain the customer type field, set the value to account or contact.
- To use a visualized service guidance flow, set the value to the name of a visualized flow configured on the Configuration Center > Workbench Configuration > Service Guidance page, that is, the name of the flow created in 7.
Actions
Button
Delete a line of call-associated data.
Click
Add
Button
Add a line of call-associated data.
Click
Cancel
Button
Cancel the editing.
Click
Confirm
Button
Fill back the call-associated data in JSON format.
Click
- Calling Number
- When Transfer Type is set to Third-party number (5), the number set here is used as the calling number.
- When Transfer Type is set to Audio and video familiar customers (9), the variable set here is used as the calling number of the customer. The default value is SYS.callingNumber.
- Enable Recording: This check box is displayed only when Transfer Type is set to Third-party number (5). You can select this check box to enable recording during call transfer from an intelligent IVR to a third-party number. After you select this check box, set the following parameters:
- Recording File Name: Enter a flow variable, for example, FLOW.recordPath.
- Recording Service Node ID: Enter a flow variable, for example, FLOW.serviceNo.
The recording files in the intelligent IVR can be played and downloaded on the Contact History > Transfer Record page.
Condition Branch Description
Condition Branch |
Description |
Usage |
SUCCESS |
Transfer success |
Triggered when a call is transferred successfully. |
FAILED |
Transfer failure |
Triggered when a call fails to be transferred. After this branch is triggered, the flow is not interrupted and does not automatically go to the exception handling flow. |
SYSERROR_INNER |
ODFS internal error |
Triggered when an unknown error occurs in the ODFS. |
Using the Diagram Element
The Call Transfer diagram element is used when a call needs to be transferred to another destination device in the AICC, for example, to a common IVR self-service flow or an agent.
Click the diagram element or drag it to the canvas, and set Transfer Type and Route Value as prompted.
Typical Application Scenario
The following describes how to use the Call Transfer diagram element to transfer a call from an intelligent IVR flow to a common IVR flow when call-associated data in JSON format is carried.
- Sign in to the AICC.
- Configure a common IVR flow.
- Choose Configuration Center > Chatbot Management > Flow Configuration and add a common IVR flow.
- Add flow variables, as shown in the following figure, and configure an Assign diagram element.
- Configure a Condition Judgement diagram element for conditional judgment based on the call-associated data.
- Configure a Voice Playback diagram element for playing a variable voice.
- Save and publish the flow.
- Configure an intelligent IVR flow.
- Choose Configuration Center > Chatbot Management > Flow Configuration.
- Choose Flow > Orchestration, add an intelligent IVR flow, add a Call Transfer diagram element, and set service parameters of the diagram element, as shown in the following figure.
- Choose Intelligent Chatbot and bind the flow to a robot.
- Choose Configuration Center > Access Configuration > Called Party and add a called route. Set the IVR to the intelligent IVR added in 3.
- Log in to the OpenEye and dial the access code added on the Called Party page. If "10000" is heard, the call-associated data (service_id: 10000) transferred by the intelligent IVR is successfully obtained.
