Help Center/ Customer Engagement Center/ User Guide/ Inspector Guide/ Processing Manual Post-Event Inspections
Updated on 2025-11-07 GMT+08:00
After an agent completes a call, an inspector can check the call content, inspect the agent, and process violations.
- Executing Inspection Tasks
An inspector can access an inspection task and inspect the calls of agents. - Viewing Inspection Results
An inspector can view inspection results. - Handling Review Applications
If an agent disagrees with an inspection result, the agent can apply for a review. An inspector with the permission can handle the review application.
Parent topic: Inspector Guide
