Help Center/ Customer Engagement Center/ User Guide/ Agent Guide/ OpenEye Help Document/ Introduction to Software Functions/ Video Communication/ Label Sharing
Updated on 2025-11-07 GMT+08:00
Label Sharing
During screen sharing, you can customize labels as required.
- Enable the sharing function during a video call by referring to Screen Sharing.
- On the sharing menu bar of a shared area, click
. Figure 1 Sharing labels on the desktop
Figure 2 Sharing labels in a specified application
Figure 3 Sharing labels in a specified area
- Verify that label sharing supports the following functions:
- Whiteboard: Switch the background between the Whiteboard and Desktop during labeling. After the background is switched, the previous labels are cleared.
- Line: Select a line tool, such as a brush, straight line, arrow, dotted line, circle, or rectangle, for labeling.
- Word: Insert text and adjust the size of the inserted text.
- Color: Select the color of lines and texts.
- Cancel: Cancel the last step.
- Save: Save the current label screenshot. The save path is the same as that of the video image screenshot. You can choose Settings > General > Screenshot Saving Path to set the save path.
- Exit: Manually exit the labeling page.
Parent topic: Video Communication
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
