Updated on 2025-11-07 GMT+08:00
Permission Settings - Chinese Version
Create a management account:
Run the ./AddAdmin.sh command in the OpenEye installation directory.
Enter the username and password and confirm the password as prompted. Set parameters in the configuration information as follows:
Permission settings:
After a management account is added, the Permission page is displayed when the system administrator starts the OpenEye.
Permissions can be set after the management account is authorized.
The Permission control option is selected by default. If this option is deselected, all operations do not need to be authorized.
The Setting option is deselected by default. Enter settingctrl=y to enable this function when adding a management account. If this option is selected, authentication is required for opening the Settings window.
The Logout option is deselected by default. Enter logoutctrl=y to enable this function when adding a management account. If this option is selected, authentication is required for logout.
The Exit option is deselected by default. Enter exitctrl=y to enable this function when adding a management account. If this option is selected, authentication is required for exiting the program.
The Login option is deselected by default. Enter loginctrl=y to enable this function when adding a management account. If this option is selected, authentication is required for modifying the login account and setting automatic login.
Separate multiple configuration parameters with spaces.
The authorization is valid until the program is restarted and the authorization can be canceled.
The password of the management account can be changed.
