Answering Inbound Calls Manually
An agent can manually answer an inbound call from a customer.
Context
An agent can manually answer an allocated inbound call. After the call is answered successfully, the agent can start talking with the customer.
- The agent has signed in.
- The agent is in idle state.
- Manual call answering has been configured in any of the following methods:
- A tenant administrator sets the parameter Agent Answering Mode under to Manual, and the parameter Indicates whether to use organization-level parameters. Tenant-level parameters are preferred. under to No.
- A tenant administrator sets the parameter Indicates whether to use organization-level parameters. Tenant-level parameters are preferred. under to Yes, and the parameter Agent Answering Mode under to Manual.
- When a tenant administrator sets the parameter Agent Answering Mode under to Custom, and the parameter Indicates whether to use organization-level parameters. Tenant-level parameters are preferred. under to No:
- The parameter Indicates whether to enable the administrator to maintain the agent-level answer mode through the agent configuration menu under is set to Yes, and the parameter Agent Answering Mode of the agent under is set to Manual Answer.
- The parameter Indicates whether to enable the administrator to maintain the agent-level answer mode through the agent configuration menu under is set to Yes, the parameter Agent Answering Mode of the agent under is not set, and the agent sets the parameter Agent answer mode under to Manual response.
- The parameter Indicates whether to enable the administrator to maintain the agent-level answer mode through the agent configuration menu under is set to No, and the agent sets the parameter Agent answer mode under to Manual response.
- When a tenant administrator sets the parameter Indicates whether to use organization-level parameters. Tenant-level parameters are preferred. under to Yes, and the parameter Agent Answering Mode under to Custom:
When a new inbound call arrives, the softphone of the agent rings. The agent can click Answer to answer the call.
- After a new inbound call arrives, the softphone of the agent rings. Click Answer.
- At this time, the call is still not connected and the agent is in the Occupied state.
- After clicking
, the agent enters the Talking state, and the softphone shows that the agent is answering a call.
