Answering Inbound Calls Automatically
An agent can automatically answer an inbound call from a customer.
Context
An agent can answer an allocated inbound call. After the call is answered successfully, the agent can start talking with the customer.
- The agent has signed in and is in idle state.
- Automatic call answering has been configured in any of the following methods:
- A tenant administrator sets the parameter Agent Answering Mode under to Automatic, and the parameter Indicates whether to use organization-level parameters. Tenant-level parameters are preferred. under to No.
- A tenant administrator sets the parameter Indicates whether to use organization-level parameters. Tenant-level parameters are preferred. under to Yes, and the parameter Agent Answering Mode under to Automatic.
- When a tenant administrator sets the parameter Agent Answering Mode under to Custom, and the parameter Indicates whether to use organization-level parameters. Tenant-level parameters are preferred. under to No:
- The parameter Indicates whether to enable the administrator to maintain the agent-level answer mode through the agent configuration menu under is set to Yes, and the parameter Agent Answering Mode of the agent under is set to Auto Answer.
- The parameter Indicates whether to enable the administrator to maintain the agent-level answer mode through the agent configuration menu under is set to Yes, the parameter Agent Answering Mode of the agent under is not set, and the agent sets the parameter Agent answer mode under to Automatic answer.
- The parameter Indicates whether to enable the administrator to maintain the agent-level answer mode through the agent configuration menu under is set to No, and the agent sets the parameter Agent answer mode under to Automatic answer.
- When a tenant administrator sets the parameter Indicates whether to use organization-level parameters. Tenant-level parameters are preferred. under to Yes, and the parameter Agent Answering Mode under to Custom:
- OpenEye:
When a new inbound call arrives, the softphone of the agent rings and the call will be automatically connected. The agent can also click Answer before the call is automatically connected. The process is described as follows:
- WebRTC:
- If the tenant parameter Whether to enable WebRTC auto-answer ringtone is set to Yes, when an agent receives an assigned inbound call, the call is automatically answered by the agent within 1 second after the phone rings. If the ringing duration is too short, the agent may hear the customer's voice and ringing tone at the same time.
- If the tenant parameter Whether to enable WebRTC auto-answer ringtone is set to No, when an agent receives an assigned inbound call, the call is automatically answered by the agent.
