Managing Task Groups
Context
Different percentages (with a sum of 100%) can be set for tasks in a task group. During data import, data is imported to specified outbound call tasks based on the percentages.
- Sign in to the AICC as a tenant administrator and choose .
- Click New. Figure 1 New Task Group page
- Task group name: The task group name must be unique in a tenant space and cannot contain the following special characters: `~!@#$%^&*()+=|{}'":;\[]/?.¥...-,
- Organization Unit: The options are as follows:
- Tenant administrator: All OUs under the current tenant are available.
- Agent:
- If the tenant parameter Has the tenant enabled inter-organization data isolation enforcement is set to Yes, OUs that can be accessed by agents are available.
- If the tenant parameter Has the tenant enabled inter-organization data isolation enforcement is set to No, all OUs are available.
- Accessible OUs selected on the Configuration Center > Employee Center > Employee > Add Employee page are available.
Contact the tenant administrator to set tenant parameters on the Configuration Center > System Management > Tenant Parameter page.
- Describe: Enter a task group description. The description cannot exceed 255 characters.
- Task Name: Only outbound call tasks in the Waiting, Completed, Suspended, Executing, or Draft state can be selected. Outbound call tasks that are already in other task groups cannot be selected.
- Contact List: View the batch name.
- Proportion(%): Enter a positive integer ranging from 1 to 100. The sum of percentages must be 100%. During data import, data is allocated based on the percentage.
- Click Save.
- Click Import. In the Import dialog box, download the outbound call data template, fill in the template, upload the file, and click OK. For details about how to import outbound call data, see Importing Outbound Call Data. Figure 2 Import
If the associated target task has expired or been archived, data cannot be imported again.
- Click Import Result to check the imported content.
- (Follow-up activity) After the outbound call data is successfully imported, access the page, enable
, and execute the outbound call task.
