Defining Outbound Call Results
Outbound call results can be defined to identify the causes of failed outbound call tasks.
Some operations under the current menu are controlled by separate permissions. If related operation permissions are not configured, the corresponding operations are not supported. For details about the operation permissions that can be configured separately, see Table 1.
Context
For failed calls, the outbound call system records cause codes based on the failed process nodes and communication signaling. Cause codes can be configured in sequence based on business scenarios. Multiple cause codes can be aggregated into one outbound call failure cause, based on which outbound call results are pushed back.
The mappings between outbound call failure causes and cause codes are preset in the system before delivery. You can customize the mappings as required.
- Sign in to the AICC as a tenant administrator and choose . Figure 1 External Result
- Click New to create an outbound call result. Figure 2 New Explicit Results page
- Configure the outbound call failure cause and click Add to add outbound call results. Figure 3 Adding outbound call results
- Select one or more outbound call results and click OK.
- Click OK.
