Updated on 2025-11-07 GMT+08:00
Configuring Business Scenarios
Inspection business scenarios can be configured. Each scenario contains multiple inspection rules. The system implements AI inspections based on business scenarios.
Context
A business scenario is a set of multiple inspection rules. A condition can be set for a business scenario. Calls that meet the condition will be inspected. An inspection rule can belong to multiple business scenarios. For example, a call of a business department belongs to business scenario A. After the business scenario is modified, inspected calls will not be inspected again. Only new calls belong to this modified business scenario will be inspected.
Only business scenarios in Enabled state can be used for AI inspections. You can manually switch the business scenario states.
You can maintain business scenarios by adding them on the GUI or by importing them offline.
In the offline scenario, you can fill in an Excel template offline and import elements such as business scenarios, semantics, keywords, sensitive words, sentences, and rules for specified AI inspection tasks.
Data that is not associated with businesses can be imported individually. For example, to import a sensitive word associated with a sentence, you need to configure the corresponding sentence data. If the sensitive word is not associated with a sentence, you can directly import it.
In the Excel template scenario, pay attention to the following:
  • One sheet corresponds to the configuration item of one element. When a template is imported, only the configuration items corresponding to the sheet with content are updated.
    The following lists the sheets in a template and the corresponding content to be entered:
    • business-scenario: Enter business scenarios.
    • intent-category: Enter sentences.
    • intent-corpus: Enter the semantics content.
    • intent-rule-corpus: Enter keywords.
    • sensitive-group-word: Enter sensitive words.
    • dialog-rule: Enter the basic content of dialog rules.
    • dialog-flow: Enter the logic content of dialog rules.
    • dialog-sentence-group: Enter sentences of dialog rules.
    • silence-rule: Enter the content of silence rules.
    • speed-rule: Enter the content of speed rules.
    • interruption-rule: Enter the content of interruption rules.
  • The business scenarios in each sheet are identified by name. If the name of a business scenario is different from that of the element of the same type in the system, the configuration item can be added. If they are the same, the configuration item cannot be added.
    If the name of a business scenario already exists in the system, update the name of the existing business scenario.
  • The column names in the Excel file can be modified based on site requirements, but they cannot be deleted. In addition, the sequence of each column must be fixed. Otherwise, errors may occur during the import.
  • Pay attention to special characters in the Excel file, such as < (less-than sign) and > (greater-than sign), which indicates hypertext tags. Otherwise, the import may fail.
Scenario 1: Adding a business scenario online
  1. Sign in to the AICC as a tenant administrator and choose Configuration Center > Quality Management > Business Scenario.
  2. Click Add to add a business scenario.
  3. On the Add Business Scenario page, set Name, Description, Call Start Time, and Call End Time, set Inspection Type to Voice Type or Text Type, select inspection rules, and click Save.
  4. In the dialog box that is displayed, click OK.
Scenario 2: Importing business data offline
  1. Download the import template from the GUI.
  2. Fill in the sheets of the import template by referring to the following table.
    The content on each sheet is imported to the corresponding configuration page in the system. If data with the same name exists on the configuration page, the import fails.
    Table 1 business-scenario sheet
    Column
    Value Example
    Scenario Name
    Business scenario name. This column is mandatory.
    Scenario Description
    Business scenario description.
    Ignore Sensitive Words
    Whether to ignore sensitive words. This parameter is mandatory.
    • 0: no
    • 1: yes
    Scenario Status
    Whether a business scenario is enabled. This parameter is mandatory.
    • 0: no
    • 1: yes
    Call Start Time
    Call start time.
    Format: YYYY/MM/DD HH:MM:SS
    Call End Time
    Call end time.
    Dialog Rule
    Dialog rule, which must be configured in the dialog-rule sheet.
    Silence Rule
    Silence rule, which must be configured in the silence-rule sheet.
    Speed Rule
    Speed rule, which must be configured in the speed-rule sheet.
    Interruption Rule
    Interruption rule, which must be configured in the interruption-rule sheet.
    Interaction Type
    Interaction type of a business scenario. If this parameter is not set, the voice type is used by default.
    • 0: voice type
    • 2: text type
    0
    Table 2 intent-category sheet
    Column
    Value Example
    Sentence Category Name
    Sentence category name. This column is mandatory.
    Sentence Name
    Sentence name. This column is mandatory.
    Sentence Category Usage
    Sentence category usage.
    • dialog_rule: dialog rule
    • speaker_identify_rule: rule for distinguishing speaker roles
    dialog_rule
    Table 3 intent-corpus sheet
    Column
    Value Example
    Sentence Name
    Corpus
    Semantic name. This column is mandatory.
    Language
    Semantic internationalization. This column is mandatory.
    • zh_CN: Chinese
    • en_US: English
    Negative Sample
    Whether the corpus is an antonym corpus. This column is mandatory.
    • false: synonym corpus.
    • true: antonym corpus.
    Full Match
    Whether the semantic content needs to be fully matched. This column is mandatory.
    • false: partial match.
    • true: full match.
    false
    Table 4 intent-rule-corpus sheet
    Column
    Value Example
    Sentence Name
    Corpus
    Keyword. This column is mandatory.
    Language
    Keyword internationalization. This column is mandatory.
    • zh_CN: Chinese
    • en_US: English
    Negative Sample
    • false: positive sample.
    • true: negative sample.
    Full Match
    Whether full match is required for the keyword content. This column is mandatory.
    • true: full match.
    false
    Table 5 sensitive-group-word sheet
    Column
    Value Example
    Sensitive Word Category Name
    Sensitive word category name. This column is mandatory.
    Sensitive Word
    Sensitive word. This column is mandatory.
    Score
    Rule score, which indicates that points are deducted for violation. This column is mandatory.
    The value is an integer ranging from –100 to 0. If this parameter is left empty, the value 0 is automatically assigned. If a decimal point exists, round down the value.
    -5
    Agent Exception
    Sentence name.
    Multiple sentences can be separated by vertical bars (|).
    Sentence name 1|Sentence name 2
    Customer Exception
    Sentence name.
    Sentence name 2
    Table 6 rule-dialogue sheet
    Column
    Value Example
    Rule Name
    Dialog rule name. This column is mandatory.
    Rule Description
    Description of a dialog rule.
    Score
    Rule score. This column is mandatory.
    The value is an integer ranging from –100 to +100. If this parameter is left empty, the value 0 is automatically assigned. If a decimal point exists, round down the value.
    • If the rule is used for point deduction, points deducted for violation are displayed.
    • If the rule is used for point adding, points added for compliance are displayed.
    • If the rule score is 0, the score is not calculated.
    -5
    Rule Type
    Rule type. This column is mandatory.
    • normal: general rule.
    • critical: important rule.
    normal
    Rule Mode
    Rule mode. This column is mandatory.
    • positive: positive rule. This rule is mandatory for compliance.
    • negative: negative rule. This rule is mandatory for violation.
    negative
    Number of Dialog Logics for Compliance
    Number of dialog logics for compliance. This column is mandatory.
    The value is an integer ranging from 1 to 100. If a decimal point exists, round down the value.
    Trigger Start Time
    Call start time.
    Trigger End Time
    Call end time.
    Table 7 dialog-flow sheet
    Column
    Value Example
    Dialog Logic Name
    Dialog logic name. This column is mandatory.
    Dialog Rule
    Sentence Group Name
    Name of the sentence group. This column is mandatory.
    Multiple sentence groups can be separated by vertical bars (|).
    Sentence group name 1|Sentence group name 2
    Expression
    Expression of a sentence group.
    • must: must say
    • must|then: must say|goes on saying
    • must|and: must say|also says
    • must|and|then: must say|also says|goes on saying
    • if|after: Before the previous sentence|must say
    • if|after|and: Before the previous sentence|must say|also says
    • if|after|then: Before the previous sentence|must say|goes on saying
    • if|iand: If says|must say (Either)
    • if|iand|and: If says|must say (Either)|also says
    • if|iand|then: If says|must say (Either)|goes on saying
    • if|then not: cannot say
    • if|then: After the previous sentence|must say
    • if|then|and: After the previous sentence|must say|also says
    • if|then|then: After the previous sentence|must say|goes on saying
    if|then not
    Minimum Number of Repetitions
    Number of times the dialog logic is repeated.
    The value is an integer ranging from 2 to 127. If a decimal point exists, round down the value.
    Table 8 dialog-sentence-group sheet
    Column
    Value Example
    Sentence Group Name
    Sentence group name. This column is mandatory.
    Dialog Rule Name
    Dialog Logic Name
    Dialog Type
    Dialog rule type. This column is mandatory.
    • must: must say
    • if: if says
    • must_say: must say
    • must_not_say: cannot say
    • then: goes on saying
    • and: also says
    Optional
    Reserved field. This parameter is mandatory.
    • true: optional
    • false: mandatory
    Dialog Role
    Matching role, which specifies whether a customer or an agent speaks in a dialog rule. This column is mandatory.
    • any: not specified.
    • staff: agent.
    • customer: customer
    any
    Call Phase
    Call phase.
    • top: beginning of a call.
    • bottom: end of a call.
    • set: sets the interval.
    any
    Interval
    Call interval. The value ranges from 1 to 9999. The value must be an integer. If a decimal point exists, round down the value.
    This column is mandatory only when Call Phase is set to top, bottom, or set.
    Sentence
    Sentence name.
    Table 9 silence-rule sheet
    Column
    Value Example
    Rule Name
    Name of a silence rule. This column is mandatory.
    Score
    -5
    Consecutive Silence Seconds for Violation
    Consecutive silence seconds for violation. This column is mandatory.
    The value is an integer ranging from 1 to 2147483647. If a decimal point exists, round down the value.
    3
    Number of Silence Times for Violation
    Number of silence times for violation. This column is mandatory.
    Trigger Start Time
    Call start time.
    Trigger End Time
    Call end time.
    Exception Settings for an Agent Before Silence
    Exception settings for an agent before silence. Enter the sentence name. Multiple sentences can be separated by vertical bars (|).
    Exception Settings for a Customer Before Silence
    Exception settings for a customer before silence. Enter the sentence name. Multiple sentences can be separated by vertical bars (|).
    Exception Settings for an Agent After Silence
    Exception settings for an agent after silence. Enter the sentence name. Multiple sentences can be separated by vertical bars (|).
    Table 10 speed-rule sheet
    Column
    Value Example
    Rule Name
    Name of a speed rule. This column is mandatory.
    Score
    -5
    Minimum Number of Words/min
    If the value is less than the value of this parameter, the speaking speed is too low and a violation is met. This parameter is mandatory.
    The value is an integer ranging from 1 to 220. If a decimal point exists, round down the value.
    180
    Maximum Number of Words/min
    If the value is greater than the value of this parameter, the speaking speed is too high and a violation is met. This parameter is mandatory.
    300
    Trigger Start Time
    Call start time.
    Trigger End Time
    Call end time.
    Customer Statement When the Speed Is Higher Than the Maximum
    Customer statement when the speed is higher than the maximum. Enter the sentence name. Multiple sentences can be separated by vertical bars (|).
    Customer Statement When the Speed Is Lower Than the Minimum
    Customer statement when the speed is lower than the minimum. Enter the sentence name. Multiple sentences can be separated by vertical bars (|).
    Table 11 interruption-rule sheet
    Column
    Value Example
    Rule Name
    Name of the interruption rule. This column is mandatory.
    Score
    -5
    Crosstalk Duration (s)
    Crosstalk seconds. This column is mandatory.
    The value is an integer ranging from 1 to 10000. If a decimal point exists, round down the value.
    5
    Number of Crosstalks
    Number of crosstalk times. This column is mandatory.
    Trigger Start Time
    Call start time.
    Trigger End Time
    Call end time.
  3. Sign in to the AICC as a tenant administrator and choose Configuration Center > Quality Management > Business Scenario.
  4. Click Import to import the business scenario file.
    If the import fails, the system displays the message "Failed to import the file. Check the data." In the dialog box that is displayed, click OK to reselect the business scenario file.
  5. Click OK. The task is successfully imported.
  6. (Optional) Select a business scenario and click Export. A message is displayed, asking you whether to download the business scenario. After you click OK, the business scenario is exported successfully.
    The dialog rules associated with the selected business scenario cannot contain sentences or sensitive words in the Uncategorized category. Otherwise, the exported Excel file cannot be imported.
    Figure 1 Uncategorized page
    A maximum of 100 records can be exported.
    Figure 2 Confirmation dialog box
