Updated on 2025-11-07 GMT+08:00
Managing Inspection Relationships
A tenant space administrator manages the organizations to which inspectors belong and allocates inspected tasks in a unified manner.
Context
You can define inspection relationships based on organizations and user groups. For example, if you want to classify user organizations by province or city, you can define inspection relationships to maintain the inspection relationships between different organizations. For a single organization, you can define whether the inspection relationship is applicable to all the members or lower-level organizations of the organization. Similarly, this also applies to the user group. You can select the relationship type when creating an inspection relationship. However, only one inspection relationship can be used.
  1. Sign in to the AICC as a tenant administrator and choose Configuration Center > Quality Management > Inspection Relationship.
    Figure 1 Page for managing inspection relationships
  2. Click Add and set the name, description, and relationship type as prompted.
    Figure 2 Page for creating an inspection relationship
  3. Click on the right of the Inspector Group text box to select an inspector group and inspectors.
    Figure 3 Dialog box for selecting inspector members
  4. Click Select an inspected member. and select an inspected member.
    Figure 4 Dialog box for selecting an inspected member
  5. Click Save.
  6. Check that a message is displayed, indicating that the settings have been saved successfully.
Follow-up Procedure
Click Modify to modify an inspection relationship.
Click Delete to delete an inspection relationship that is no longer used.
