Typical Scenario: Configuring Manual Inspection Tasks
Manual inspection refers to the process in which an inspector extracts details from call records based on specified inspection rules, plays back the records, and evaluates agent services based on the rating criteria.
To enable the inspection, create rating items and templates, maintain inspection relationships, and configure the policy for extracting call details in advance.
Context
After the tenant space is enabled, the administrator needs to configure the following items for inspectors in the tenant space to execute inspection tasks.
Scenario Description
The following rating rules are specified in a call center to evaluate the agent standardized service, attitude, and skills during calls:
- Service Awareness
- Whether an agent answers questions effectively.
- Whether an agent confirms with a customer about other questions before the service ends.
- Process Specifications
- Whether an agent begins with greetings and a self-introduction.
- Whether an agent ends a call with a statement similar to the following: "Thanks for calling. If you have any additional questions, please call us."
- Service Attitude
- Whether an agent argues with a customer.
The current inspection task lasts one week.
- Configure rating items.
- Choose .
- Select the rating categories on the left in sequence and click Add on the right to add the rating items in Context by referring to Configuring Rating Items.
Service Awareness, Process Specifications, and Service Attitude are preset. If these categories are unavailable, they may be deleted by other operators. Click
to add the categories.
- Configure a rating item template.
- Choose .
- Click Add on the right to add Agent inspection rating template by referring to Configuring Rating Templates.
- Save the settings and click Release.
- Configure an inspection task.
- Choose .
- Click Add on the right to add Agent inspection task of September by referring to Configuring Inspection Tasks.
Set Task Type and Channel to Manual post-event inspection and Audio, respectively.
Currently, the AICC supports manual post-event inspection only for voice and multimedia channels. The features corresponding to other options will be implemented in later versions.
If no inspector is available, check whether you have configured the Quality checker role in Prerequisites.
- Click Release.
Follow-up Procedure
After an inspection task is added, the specified inspector can perform the following operations within the task validity period:
- Choose to view the inspection task.
- Click Task. On the page that is displayed, click Obtain To-Be-Inspected Record to view the call records that can be inspected.
If no record is available, the inspector added to the inspection task has not completed a call and generated a call record.
- Click Start Inspection. On the Manual Inspection page, rate the desired record based on the rating items and click Submit.
