Help Center/ Customer Engagement Center/ User Guide/ Tenant Administrator Guide/ Managing Cases/ Case 2.0 Operation Guide/ Case Handling/ Searching for Cases
Updated on 2025-11-07 GMT+08:00
Searching for Cases
- Sign in to the AICC, choose , enter a case title, and press Enter to search for the case.
- Click Advanced Search and set advanced search criteria to search for cases. Figure 1 Advanced Search
- Filter cases by tab page. You can view cases on the Todo, Unassigned, What I'm concerned about, What I created, Processed, or All tab page. Figure 2 Tab page
- Click
to export cases based on filter criteria. - Click
to customize the view. Select the columns to be displayed in the list. To restore the default configuration, click Reset. Only icons for Whether To Upgrade and Restart Or Not are displayed next to case numbers, as shown in Figure 4. Figure 3 Column configuration
Table 1 Default fields in the list Parameter
Not Displayed
Sequence Adjustment Supported or Not
Display by Default
Case Title
No
Yes
Yes
Case Type
No
Yes
Yes
Case No.
No
Yes
Yes
Case State
No
Yes
Yes
Parent topic: Case Handling
