Help Center/
Customer Engagement Center/
User Guide/
Tenant Administrator Guide/
Managing Cases/
Case 2.0 Operation Guide/
Case Configuration/
Case Reminder
Updated on 2025-11-07 GMT+08:00
Case Reminder
- The Case 2.0 feature has been enabled for the tenant space.
- You have the Case Management 2.0 > Case > Case Configuration permission.
- To ensure that SMS messages and emails can be sent, you have configured an SMS gateway and an email gateway in advance.
- Sign in to the AICC and choose Configuration Center > Case Configuration 2.0 > Case Configuration > Case Reminder. Currently, automatic notification, case reminder notification, and customer notification are supported.
Figure 1 Case Reminder
Configuring Automatic Notification
- Enable Automatically send notifications.
Figure 2 New Automatic Notification
- Enter a notification name.
- Select a notification scenario. Currently, the options are Create, Close, Pause, Restore, Cancel, Transfer, Merge, Reboot, and ReOpenHis.
- Choose to send a case reminder via email or SMS message.
- If the case title, case ID, case details link, or other fields do not have fixed values during email filling, insert variables to automatically fill in the email subject and body, reducing the number of case reminder rule setting times. For details about how to create variables, see Customized Case Field.
- Click .
- (Follow-up operations) Access the case details page and change the case owner, for example, transfer a case, restart a historical case, merge cases, restart a case, or create a case. An automatic notification is triggered. You can click
to view the email or SMS notification on the Notification Center page.
Figure 3 Transfer Case
Figure 4 Notification Center
Configuring a Case Reminder Notification
- Click the Reminder Notification tab, and then click Create.
Figure 5 Create Reminder Notification page
- Click .
- (Follow-up operation) On the case details page, click to manually send a case reminder. Alternatively, on the case workbench, click reminder to manually send a case reminder. After a case reminder is sent, the case owner receives the email or SMS notification.
Figure 6 Manually sending a case reminder
Figure 7 reminder button on the case workbench
- (Optional) If you use the Case for the first time and have not configured case reminder notification, you can go to the case details page and click
to send a case reminder. The system sends an email to the corresponding owner by default.
Figure 8 Case reminder notification disabled
Configuring a Customer Notification
- Click the Customer Notification tab, and then click Create.
Figure 9 Create Customer Notification page
- View the default template provided for customer notification. By default, the information shown in the preceding figure is used in the initial environment.
- Modify the information as required.
- Set parameters. All parameters on the Create Customer Notification page are mandatory.
- Enter an email subject.
- If the case title, case ID, case details link, or other fields do not have fixed values during email body filling, insert variables to automatically fill in the body, reducing the number of case reminder rule setting times.
- Click .
- (Follow-up operation) Sign in to the AICC, choose , and select Notified by Email or Notified by SMS when creating a case to notify the customer after the case is created. Alternatively, go to the case details page, change the case status, and select Notified by Email or Notified by SMS to notify the customer of the case status change.
Parent topic: Case Configuration
