IVR Overview
On the IVR Overview page, you can view the overall operations status of a selected chatbot flow from a macro perspective.
- You have the IVR Analysis > IVR Overview menu permission.
- The IVR analysis and intelligent IVR features have been enabled for the tenant space.
- The chatbot flow to be analyzed has call records in the query time range.
- Sign in to the AICC and choose IVR Analysis > IVR Overview.
- Set the access code, version name, and time range in the filter criteria boxes and press Enter. The query result is displayed, as shown in Figure 2.
- In the Operation Status area, learn about the overall status of IVR operations.
The Operation Status area displays the overall IVR operations status based on the month-on-month increase or decrease rate of core KPIs of IVR flows (arithmetic average value of the absolute values of the month-on-month (MoM) rates of all core KPIs).
If the average increase or decrease rate of core KPIs is less than 5%, the operations status is Good. If the increase or decrease rate ranges from 5% to 10%, the operations status is General. If the increase or decrease rate is greater than 10%, the operations status is Poor and the situation needs to be handled in time. If no MoM value is available, the operations status is set to Good by default.
- Click More to go to the Alarm Event page. For details, see Alarm Event.
- In the Business Rankings area, click a node name to go to the Flow Analysis page. For details, see Flow Analysis. Figure 2 Node name
- Success rate = ∑Number of successes (SuccessCalls)/∑Number of visits (journeynum)
- Failure rate = ∑Number of failures (FailedCalls)/∑Number of visits (journeynum)
- Hang-up rate = ∑Number of calls that are hung up (HangupNum)/∑Number of visits (journeynum)
- (Follow-up procedure) Learn about the descriptions and formulas of KPIs. For details, see KPI Description.
