Analytics Description
Table 1 lists analytics reports and functions provided by CDN.
Item |
Description |
Check the traffic/bandwidth usage, number of requests, and number of queries per second (QPS) of user requests to domain names, and export the detailed data. |
Check the traffic/bandwidth usage, number of requests, and failure rates of origin pulls from domain names, and export the detailed data. |
Check the traffic usage and request hit ratios of domain names, and export the hit ratio details. |
Check the status codes of user requests to domain names, and export the status code details. |
Report domain name metrics to Cloud Eye for timely monitoring. |
Check details about metric reported to Cloud Eye to monitor metric anomalies and promptly adjust services. |
Customize operations reports for domain names to check statistics in different periods, monitor the domain status, and promptly adjust services. |
Check offline domain statistics in operations reports, analyze the domain status, and adjust operations policies properly. |
Check the traffic/bandwidth usage of domain names. |
Check the total traffic/bandwidth usage and number of whole site acceleration requests of domain names on a specific day. |
Check the traffic/bandwidth usage and number of requests of domain names whose service type is whole site acceleration. |
Export statistics about all or specific domain names. |
If you have enabled the enterprise project function for your account, note the following:
- Deleted domain names are not counted.
- If a domain name is migrated from enterprise project C to enterprise project D under the same account, its statistics are no longer available under enterprise project C. Its statistics before and after the migration are displayed in enterprise D.
If the enterprise project function is not enabled, you can view the historical statistics of deleted domain names generated in the past 90 days.
- On the CDN console, there is a delay of about 1 hour for data on the Analytics and Overview pages.
