Monitoring Dashboard
If you have reported metrics related to acceleration domain names to Cloud Eye, you can view them on the monitoring dashboard.
- You have added domain names to be monitored. For details, see Cloud Eye Monitoring.
- You have set domain name alarm rules.
Log in to the CDN console.
- In the navigation pane, choose .
- Click the Dashboard tab to check monitoring information.
- Monitored Domains: displays domain names whose metrics are reported to Cloud Eye.
- Alarms Today: displays the severity distribution of alarms generated today. If no alarm rule is configured or no alarm is generated for the domain names, you can click Create Now to use recommended alarm rules or customize alarm rules.
- The system provides the built-in one-click alarm function, including alarm rules for status codes 4xx and 5xx. You can enable Enabling Recommendation Alarms to use this function.
- To adjust the default alarm rules, click Cloud Eye One-Click Alarm to go to the Cloud Eye console.
- To adjust the notification policies, click Create Notification Policy to go to the Cloud Eye console.
- If existing alarm rules cannot meet your needs, click Create alarm rules to create one.
Figure 1 Recommended alarm configurations
- 5 Domains with the Most Alarms: displays five domain names with the most alarms.
- If no alarm rule is configured or no alarm is generated for the domain names, you can click Create Now to use recommended alarm rules or customize alarm rules.
- View metrics by domain name.
Creating an Alarm Rule
In the Alarm Configuration drawer, click Create alarm rules.
| Parameter | Description |
| Name | Name of the alarm rule. The system generates a random name, which you can modify. Example value: alarm-poxz |
| Monitoring Scope | Resources to which the alarm rule applies. Only All resources can be selected. |
| Alarm Policy | Condition for triggering an alarm. When the specified event occurs, an alarm will be triggered. |
| Notification Policies | Combination of parameters, such as notification group, window, and template. |
