Updated on 2025-04-24 GMT+08:00
Summary
Check the total traffic/bandwidth usage and number of whole site acceleration requests of domain names on a specific day on the CDN console.
If you have enabled the enterprise project function for your account, note the following:
  1. Deleted domain names are not counted.
  2. If a domain name is migrated from enterprise project C to enterprise project D under the same account, its usage summary is no longer available under enterprise project C. Its summary before and after the migration is displayed in enterprise D.
If the enterprise project function is not enabled, you can view the historical usage summary of deleted domain names generated in the past 90 days.
Precautions
  • You can view the usage data of a day in the last 90 days.
  • By default, statistics about domain names are displayed by region (Chinese mainland and outside the Chinese mainland).
  1. Log in to Huawei Cloud console. Choose Service List > Content Delivery & Edge Computing > Content Delivery Network.
    The CDN console is displayed.
  2. In the navigation pane, choose Analytics > Traffic Query.
  3. Click the Summary tab and select a date.
    • You can export summary data.
    Figure 1 Summary
