Query
Check the traffic/bandwidth usage of domain names on the CDN console.
If you have enabled the enterprise project function for your account, note the following:
- Deleted domain names are not counted.
- If a domain name is migrated from enterprise project C to enterprise project D under the same account, its usage details are no longer available under enterprise project C. Its usage details before and after the migration are displayed in enterprise D.
If the enterprise project function is not enabled, you can view the historical usage details of deleted domain names generated in the past 90 days.
If the service area of your domain name is Global, you must query the statistics of this domain name by choosing Chinese mainland and International respectively. Query by Global is not available.
Precautions
- You can query data from the last 90 days. Each query covers up to 31 days.
- If no data is available for the queried domain name within the specified time span, no data is displayed in the traffic or bandwidth trend chart.
- The minimum granularity is 5 minutes. If the query time range is eight days or longer, the minimum granularity is 1 hour.
- The logged traffic statistics are displayed. However, the billable traffic is 10% higher than the logged statistics because TCP/IP packet headers and TCP retransmissions also consume traffic.
- The current usage can be queried about one hour later.
- You can export the query results.
- You can filter domain names by tag or service type.
Log in to the CDN console.
- In the navigation pane, choose .
- Click the Traffic Query tab and set search criteria. You can query the following data:
- Traffic: displays the traffic of specific domain names over time.
- Bandwidth: displays the peak bandwidth of specific domain names over time.
Figure 1 Traffic/Bandwidth trend
The 95th percentile bandwidth and the average daily peak bandwidth are both shown for the same time span. If no bandwidth statistics are generated within the queried time span, the 95th percentile bandwidth line or the average daily peak bandwidth line is not displayed.
