Cloud Eye Monitoring
You can interconnect CDN with Cloud Eye to monitor CDN metrics, such as traffic, bandwidth, and traffic hit ratio. CDN reports domain data to Cloud Eye in real time. You can also set alarm rules. When the value of a metric exceeds the alarm threshold, an alarm is generated. This helps you learn about the business status in real time and prevent risks in a timely manner.
Precautions
- Domain names with special configurations are not supported.
- Data reporting latency is typically about 4 minutes. This latency may increase in special cases, such as edge-node network jitter. During these periods, monitoring data may be temporarily unavailable in Cloud Eye.
- Data of accounts that enabled Cloud Eye monitoring before October 30, 2024 (UTC+08:00) will be reported to the CN North-Beijing4 region of Cloud Eye. Data of accounts that enabled Cloud Eye monitoring after October 30, 2024 (UTC+08:00) will be reported to the AP-Singapore region of Cloud Eye.
Enable Cloud Eye in the AP-Singapore region before reporting monitoring data there for the first time.
- Cloud Eye monitoring is free of charge on CDN. If you configure alarms on Cloud Eye, SMN will charge you for alarm notifications sent to you. For details about SMN pricing, see SMN Pricing Details.
- Log in to the CDN console.
- In the navigation pane, choose .
- Click the Dashboard tab.
- In the Cloud Eye Monitoring area, click Add Domains and add domain names to report their metrics to Cloud Eye.
- If Scope is set to All domains, all monitoring data for your domain names, including those added to CDN later, is reported to Cloud Eye.
- If Scope is set to Specified domains, data of the domain names selected under Domain Names is reported to Cloud Eye. A maximum of 100 domain names can be added.
Figure 1 Adding domain names
- Add the domain names whose data needs to be reported and click OK.
Stopping Monitoring
- If you set Scope to All domains, you cannot stop monitoring for a specific domain name.
- If you set Scope to Specified domains, you can delete a domain name to stop monitoring it.
- Locate the domain name to be deleted and click Delete Domain in the Operation, confirm the information, enter DELETE, and click OK.
- Select multiple domain names to be deleted, click Delete Domain above the domain name list, confirm the information, and enter DELETE to delete the domain names.
