Status Codes
HTTP status codes indicate whether requests to a domain name are processed successfully. You can use these status codes to identify and troubleshoot abnormal requests. Detailed status code statistics are available in the CDN console.
If you have enabled the enterprise project function for your account, note the following:
- Deleted domain names are not counted.
- If a domain name is migrated from enterprise project C to enterprise project D under the same account, its status code statistics are no longer available under enterprise project C. Its statistics before and after the migration are displayed in enterprise D.
If the enterprise project function is not enabled, you can view the historical status code statistics of deleted domain names generated in the past 90 days.
Precautions
- You can query data from the last 90 days. Each query covers up to 31 days.
- The minimum granularity is 5 minutes. If the query time range is eight days or longer, the minimum granularity is 1 hour.
- There is a delay of about one hour for data displayed on the Status Codes tab.
- You can filter domain names by tag, service type, region, and enterprise project.
- You can export status code statistics.
- Log in to the CDN console.
- In the navigation pane, choose .
- Click the Status Codes tab and set search criteria (such as service type, domain name, and time). You can query the following data:
- Status Codes: displays the number of appearances of status codes of each type in the query period. You can view the trend chart of a status code. Status codes include 2XX, 3XX, 4XX, and 5XX. For details, see Table 1.
- Overview: displays the total number and proportion of appearances of each type of status codes in the query period.
- Details: displays the total number and proportion of each status code in the query period. You can also click Check Details to check domain names of this status code. Figure 1 Status code statistics
Table 1 Status code description Status Code
2XX
Success. A request has been accepted and processed by the server.
3XX
Redirection. The client needs to perform further operations to complete the request.
4XX
Client error. There was an error on the client side, including but not limited to syntax errors or failure to complete the request.
5XX
Server error. There was an error when the server was processing the request.
