Access Requests
Check the traffic/bandwidth usage and number of requests/QPS of domain names by visitor region or carrier on the CDN console.
If you have enabled the enterprise project function for your account, note the following:
- Deleted domain names are not counted.
- If a domain name is migrated from enterprise project C to enterprise project D under the same account, its access statistics are no longer available under enterprise project C. Its statistics before and after the migration are displayed in enterprise D.
If the enterprise project function is not enabled, you can view the historical access statistics of deleted domain names generated in the past 90 days.
Precautions
- Data of the past 90 days can be queried, and each query can include data of up to 31 days.
- If no data is available for the queried domain name within the specified time span, no data is displayed in the trend charts.
- The minimum granularity is 5 minutes. If the query time range is eight days or longer, the minimum granularity is 1 hour.
- There is a delay of about one hour for data displayed on the Access Requests tab.
- You can export the query results.
- You can filter statistics by tag, service type, region, carrier, HTTP version, and Internet Protocol (IP) version.
- You can compare data.
- Log in to Huawei Cloud console. Choose .
The CDN console is displayed.
- In the navigation pane, choose .
- Click the Access Requests tab and set search criteria. You can query the following data:
- Period over period change: displays the data comparison result between the current statistical period and the previous period.
- Traffic/Bandwidth: displays the traffic/bandwidth of specific domain names over time.
- The 95th percentile bandwidth and the average daily peak bandwidth are both shown for the same time span. If no bandwidth statistics are generated within the queried time span, the 95th percentile bandwidth line or the average daily peak bandwidth line is not displayed.
- You can view the comparison between the IPv4 and IPv6 traffic.
- Requests/Queries per Second (QPS): displays the number of requests or queries per second of specific domain names over time.
- You can view the comparison between the number of IPv4 requests and IPv6 requests.
Figure 1 Data trend charts
