Help Center/
Content Delivery Network/
User Guide/
Monitoring and Auditing/
Cloud Eye for Monitoring/
Viewing Monitoring Metrics
Updated on 2025-05-19 GMT+08:00
Cloud Eye can help you monitor the status of domain names. You can obtain the monitoring metrics of CDN on the Cloud Eye console.
Precautions
- Data of accounts that enabled Cloud Eye monitoring before October 30, 2024 (UTC+08:00) will be reported to the CN North-Beijing4 region of Cloud Eye. Data of accounts that enabled Cloud Eye monitoring after October 30, 2024 (UTC+08:00) will be reported to the AP-Singapore region of Cloud Eye.
- Log in to Huawei Cloud console. Choose .
- Click
in the upper left corner of the console and select AP-Singapore or CN North-Beijing4.
- In the navigation pane, choose .
- Click Content Delivery Network CDN.
- Click a domain name in the ID column or click View Metric in the Operation column to view the monitoring metrics of the domain name.
Parent topic: Cloud Eye for Monitoring
