Updated on 2025-05-19 GMT+08:00
Setting Alarm Rules
You can customize monitoring metrics and notification policies in an alarm rule to learn about the status of domain names in a timely manner. This section describes how to set alarm rules.
You have configured Cloud Eye Monitoring.
Precautions
  • Data of accounts that enabled Cloud Eye monitoring before October 30, 2024 (UTC+08:00) will be reported to the CN North-Beijing4 region of Cloud Eye. Data of accounts that enabled Cloud Eye monitoring after October 30, 2024 (UTC+08:00) will be reported to the AP-Singapore region of Cloud Eye.
  1. Log in to Huawei Cloud console. Choose Service List > Management & Governance > Cloud Eye.
  2. Click in the upper left corner of the console and select AP-Singapore or CN North-Beijing4.
  3. In the navigation pane, choose Alarm Management > Alarm Rules.
  4. In the upper right corner of the page, click Create Alarm Rule.
  5. Set parameters as prompted.
    For more information, see Creating an Alarm Rule. The key parameters are as follows:
    • Name: alarm rule name. The system generates a random name, which you can modify.
    • Alarm Type: Metric
    • Cloud product: Content Delivery Network - Domain Name
    • Resource Level: Specific dimension
    • Monitoring Scope: Select All resources, Resource groups, or Specific resources.
  6. After the configuration is complete, click Create.
