CDN Metrics
After CDN monitoring metrics are reported to Cloud Eye, you can view the data on the Cloud Eye console in real time. This section describes the metrics reported to Cloud Eye.
Namespace
SYS.CDN
Supported CDN Metrics
ID |
Name |
Description |
Minimum Unit |
Conversion Unit |
Monitoring Period (Original Value) |
bw |
Bandwidth |
Average bandwidth of a domain name within one minute (Traffic within one minute x 8/60) |
bit/s |
1,000 |
1 minute |
flux |
Traffic |
Total traffic of a domain name within one minute |
Byte |
1,024 |
1 minute |
bs_bw |
Origin pull bandwidth |
Average origin pull bandwidth of a domain name within one minute (Origin pull traffic within one minute x 8/60) |
bit/s |
1,000 |
1 minute |
bs_flux |
Origin pull traffic |
Total origin pull traffic of a domain name within one minute |
Byte |
1,024 |
1 minute |
bs_num |
Origin pulls |
Number of origin pulls of a domain name within one minute |
Count |
1 minute |
bs_fail_num |
Failed origin pulls |
Number of failed origin pulls of a domain name within one minute |
Count |
1 minute |
bs_fail_rate |
Origin pull failure rate |
Percentage of failed origin pulls of a domain name within one minute (Number of failed origin pulls/Total number of origin pulls x 100) |
1 minute |
req_num |
Requests |
Number of requests of a domain name within one minute |
Count |
1 minute |
hit_flux |
Hit traffic |
Traffic generated when requests to a domain name hit the cache within one minute |
Byte |
1,024 |
1 minute |
hit_flux_rate |
Traffic hit ratio |
Percentage of hit traffic of a domain name within one minute (Hit traffic/Traffic x 100) |
1 minute |
avg_req_time |
Average request duration |
Average request duration of a domain name within one minute (Total request duration/Number of requests) |
ms |
1 minute |
http_code_2xx |
Status codes 2xx |
Total appearances of HTTP status codes 2xx returned for a domain name within one minute |
Count |
1 minute |
http_code_3xx |
Status codes 3xx |
Total appearances of HTTP status codes 3xx returned for a domain name within one minute |
Count |
1 minute |
http_code_4xx |
Status codes 4xx |
Total appearances of HTTP status codes 4xx returned for a domain name within one minute |
Count |
1 minute |
http_code_5xx |
Status codes 5xx |
Total appearances of HTTP status codes 5xx returned for a domain name within one minute |
Count |
1 minute |
http_code_2xx_rate |
Percentage of status codes 2xx |
Percentage of HTTP status codes 2xx returned for a domain name within one minute (Appearances of status codes 2xx/Total number of requests x 100) |
1 minute |
http_code_3xx_rate |
Percentage of status codes 3xx |
Percentage of HTTP status codes 3xx returned for a domain name within one minute (Appearances of status codes 3xx/Total number of requests x 100) |
1 minute |
http_code_4xx_rate |
Percentage of status codes 4xx |
Percentage of HTTP status codes 4xx returned for a domain name within one minute (Appearances of status codes 4xx/Total number of requests x 100) |
1 minute |
http_code_5xx_rate |
Percentage of status codes 5xx |
Percentage of HTTP status codes 5xx returned for a domain name within one minute (Appearances of status codes 5xx/Total number of requests x 100) |
1 minute |
bs_http_code_2xx |
Origin status codes 2xx |
Total appearances of origin HTTP status codes 2xx returned for a domain name within one minute |
Count |
1 minute |
bs_http_code_3xx |
Origin status codes 3xx |
Total appearances of origin HTTP status codes 3xx returned for a domain name within one minute |
Count |
1 minute |
bs_http_code_4xx |
Origin status codes 4xx |
Total appearances of origin HTTP status codes 4xx returned for a domain name within one minute |
Count |
1 minute |
bs_http_code_5xx |
Origin status codes 5xx |
Total appearances of origin HTTP status codes 5xx returned for a domain name within one minute |
Count |
1 minute |
bs_http_code_2xx_rate |
Percentage of origin status codes 2xx |
Percentage of origin HTTP status codes 2xx returned for a domain name within one minute (Appearances of origin status codes 2xx/Total number of origin pull requests x 100) |
1 minute |
bs_http_code_3xx_rate |
Percentage of origin status codes 3xx |
Percentage of origin HTTP status codes 3xx returned for a domain name within one minute (Appearances of origin status codes 3xx/Total number of origin pull requests x 100) |
1 minute |
bs_http_code_4xx_rate |
Percentage of origin status codes 4xx |
Percentage of origin HTTP status codes 4xx returned for a domain name within one minute (Appearances of origin status codes 4xx/Total number of origin pull requests x 100) |
1 minute |
bs_http_code_5xx_rate |
Percentage of origin status codes 5xx |
Percentage of origin HTTP status codes 5xx returned for a domain name within one minute (Appearances of origin status codes 5xx/Total number of origin pull requests x 100) |
1 minute |
http_code_400 |
Status code 400 |
Total appearances of HTTP status code 400 returned for a domain name within one minute |
Count |
1 minute |
http_code_403 |
Status code 403 |
Total appearances of HTTP status code 403 returned for a domain name within one minute |
Count |
1 minute |
http_code_404 |
Status code 404 |
Total appearances of HTTP status code 404 returned for a domain name within one minute |
Count |
1 minute |
http_code_416 |
Status code 416 |
Total appearances of HTTP status code 416 returned for a domain name within one minute |
Count |
1 minute |
http_code_499 |
Status code 499 |
Total appearances of HTTP status code 499 returned for a domain name within one minute |
Count |
1 minute |
http_code_500 |
Status code 500 |
Total appearances of HTTP status code 500 returned for a domain name within one minute |
Count |
1 minute |
http_code_502 |
Status code 502 |
Total appearances of HTTP status code 502 returned for a domain name within one minute |
Count |
1 minute |
http_code_503 |
Status code 503 |
Total appearances of HTTP status code 503 returned for a domain name within one minute |
Count |
1 minute |
http_code_504 |
Status code 504 |
Total appearances of HTTP status code 504 returned for a domain name within one minute |
Count |
1 minute |
http_code_400_rate |
Percentage of status code 400 |
Percentage of HTTP status code 400 returned for a domain name within one minute (Appearances of status code 400/Total number of requests x 100) |
1 minute |
http_code_403_rate |
Percentage of status code 403 |
Percentage of HTTP status code 403 returned for a domain name within one minute (Appearances of status code 403/Total number of requests x 100) |
1 minute |
http_code_404_rate |
Percentage of status code 404 |
Percentage of HTTP status code 404 returned for a domain name within one minute (Appearances of status code 404/Total number of requests x 100) |
1 minute |
http_code_416_rate |
Percentage of status code 416 |
Percentage of HTTP status code 416 returned for a domain name within one minute (Appearances of status code 416/Total number of requests x 100) |
1 minute |
http_code_499_rate |
Percentage of status code 499 |
Percentage of HTTP status code 499 returned for a domain name within one minute (Appearances of status code 499/Total number of requests x 100) |
1 minute |
http_code_500_rate |
Percentage of status code 500 |
Percentage of HTTP status code 500 returned for a domain name within one minute (Appearances of status code 500/Total number of requests x 100) |
1 minute |
http_code_502_rate |
Percentage of status code 502 |
Percentage of HTTP status code 502 returned for a domain name within one minute (Appearances of status code 502/Total number of requests x 100) |
1 minute |
http_code_503_rate |
Percentage of status code 503 |
Percentage of HTTP status code 503 returned for a domain name within one minute (Appearances of status code 503/Total number of requests x 100) |
1 minute |
http_code_504_rate |
Percentage of status code 504 |
Percentage of HTTP status code 504 returned for a domain name within one minute (Appearances of status code 504/Total number of requests x 100) |
1 minute |
bs_http_code_400 |
Origin status code 400 |
Total appearances of origin HTTP status code 400 returned for a domain name within one minute |
Count |
1 minute |
bs_http_code_403 |
Origin status code 403 |
Total appearances of origin HTTP status code 403 returned for a domain name within one minute |
Count |
1 minute |
bs_http_code_404 |
Origin status code 404 |
Total appearances of origin HTTP status code 404 returned for a domain name within one minute |
Count |
1 minute |
bs_http_code_416 |
Origin status code 416 |
Total appearances of origin HTTP status code 416 returned for a domain name within one minute |
Count |
1 minute |
bs_http_code_499 |
Origin status code 499 |
Total appearances of origin HTTP status code 499 returned for a domain name within one minute |
Count |
1 minute |
bs_http_code_500 |
Origin status code 500 |
Total appearances of origin HTTP status code 500 returned for a domain name within one minute |
Count |
1 minute |
bs_http_code_502 |
Origin status code 502 |
Total appearances of origin HTTP status code 502 returned for a domain name within one minute |
Count |
1 minute |
bs_http_code_503 |
Origin status code 503 |
Total appearances of origin HTTP status code 503 returned for a domain name within one minute |
Count |
1 minute |
bs_http_code_504 |
Origin status code 504 |
Total appearances of origin HTTP status code 504 returned for a domain name within one minute |
Count |
1 minute |
bs_http_code_400_rate |
Percentage of origin status code 400 |
Percentage of origin HTTP status code 400 returned for a domain name within one minute (Appearances of origin status code 400/Total number of origin pull requests x 100) |
1 minute |
bs_http_code_403_rate |
Percentage of origin status code 403 |
Percentage of origin HTTP status code 403 returned for a domain name within one minute (Appearances of origin status code 403/Total number of origin pull requests x 100) |
1 minute |
bs_http_code_404_rate |
Percentage of origin status code 404 |
Percentage of origin HTTP status code 404 returned for a domain name within one minute (Appearances of origin status code 404/Total number of origin pull requests x 100) |
1 minute |
bs_http_code_416_rate |
Percentage of origin status code 416 |
Percentage of origin HTTP status code 416 returned for a domain name within one minute (Appearances of origin status code 416/Total number of origin pull requests x 100) |
1 minute |
bs_http_code_499_rate |
Percentage of origin status code 499 |
Percentage of origin HTTP status code 499 returned for a domain name within one minute (Appearances of origin status code 499/Total number of origin pull requests x 100) |
1 minute |
bs_http_code_500_rate |
Percentage of origin status code 500 |
Percentage of origin HTTP status code 500 returned for a domain name within one minute (Appearances of origin status code 500/Total number of origin pull requests x 100) |
1 minute |
bs_http_code_502_rate |
Percentage of origin status code 502 |
Percentage of origin HTTP status code 502 returned for a domain name within one minute (Appearances of origin status code 502/Total number of origin pull requests x 100) |
1 minute |
bs_http_code_503_rate |
Percentage of origin status code 503 |
Percentage of origin HTTP status code 503 returned for a domain name within one minute (Appearances of origin status code 503/Total number of origin pull requests x 100) |
1 minute |
bs_http_code_504_rate |
Percentage of origin status code 504 |
Percentage of origin HTTP status code 504 returned for a domain name within one minute (Appearances of origin status code 504/Total number of origin pull requests x 100) |
1 minute |
Dimension
Key |
Value |
domain_name |
Domain name |
