Client Request Rate Limiting
You can limit the user request rate within a specific range to reduce costs and the risk of burst bandwidth.
Precautions
- Rate limiting takes effect for all user requests to the domain name, which affects the acceleration effect and user experience.
- You can configure up to 60 rate-limiting rules.
- You can configure only one rate limiting rule for All files.
- Log in to the CDN console.
- In the navigation pane, choose .
- In the domain list, click the target domain name. The Overview page is displayed.
- In the full configuration directory, click the More Service Configurations tab.
- In the Request Rate Limiting area, click Edit.
- Click Add to add a rule. Figure 1 Configuring request rate limiting
Table 1 Parameter description Parameter
Content Type
All files
Directory: files in a specific directory
Content
- This parameter is left blank when Content Type is set to All files.
- When Content Type is set to Directory, specify this parameter.
- Start with a slash (/), for example, /test/folder.
- Do not end with a slash (/).
- Enter one directory per rule.
Rate Limit Type
Rate limiting by transmission traffic is supported. That is, when the traffic of a single HTTP request reaches the specified value, the access speed is limited. The access speed of subsequent requests cannot exceed the specified rate limit.
Rate Limit Condition
Volume of the transmitted traffic that triggers rate limiting.
- The unit is byte. The maximum value is 1 GB, that is, 1,073,741,824 bytes.
- If the rate limit condition is set to 0, rate limiting will be applied to all requests to the acceleration domain name within the specified rate limiting periods. Exercise caution when setting this parameter.
Rate Limit
Maximum access speed when rate limiting starts.
- The maximum value is 100 Mbit/s.
- If the rate limit is set to 0 or too low, clients may be unable to access the acceleration domain name or may experience slow access during the specified rate limiting periods. Exercise caution when setting the rate limit.
Periods
Periods when the rate is limited, in the 24-hour clock. Period format: HHMM-HHMM (in UTC+08:00). Periods are separated by commas (,). Example: 0100-0200,2200-2300. Default value: 0000-2400, indicating all day.
- You can set up to 10 periods.
Priority
Priority of a rate-limiting rule. Each cache rule must have a unique priority. If multiple rate-limiting rules are configured for a resource, CDN uses the rate-limiting rule with the highest priority.
- Enter an integer ranging from 1 to 1,000. A greater number indicates a higher priority.
- Set required parameters and click Save.
Helpful Links
Modifying the Full Domain Configuration to modify request rate limiting settings
