Configuring TLS Versions and Cipher Suites
You can configure TLS versions and cipher suites as required.
Background
TLS is a security protocol used to ensure security and data integrity for Internet communication. The most typical application is HTTPS. TLS 1.0, TLS 1.1, TLS 1.2, and TLS 1.3 are available. A later version is more secure, but is less compatible with browsers of earlier versions.
A cipher suite is a combination of encryption algorithms used by the server and client. Suites typically use TLS or SSL. In a TLS handshake, the client notifies the server of the list of supported cipher suites. The server then picks one that both sides support.
| TLS Version | Mainstream Browser |
| TLS 1.0 |
| TLS 1.1 |
| TLS 1.2 |
| TLS 1.3 |
- Before configuring the TLS versions, configure an international HTTPS certificate first. For details, see Configuring an HTTPS Certificate.
- If the domain name is bound to a certificate with Chinese cryptographic algorithm, TLS versions cannot be configured.
- If you change the certificate type from International to Chinese (SM2), TLS version settings will become invalid.
- If you set two certificates for a domain name, TLS version settings take effect only for the international certificate.
- You can enable a single version or consecutive versions. For example, you cannot enable TLS 1.0 and TLS 1.2 but disable TLS 1.1.
- You need to enable at least one version.
- By default, TLS 1.1, TLS 1.2, and TLS 1.3 are enabled.
- TLS versions cannot be configured for domain names with special configurations.
- Log in to the CDN console.
- In the navigation pane, choose .
- In the domain list, click the target domain name. The Overview page is displayed.
- In the full configuration directory, click the HTTPS Settings tab.
- In the TLS Versions and Cipher Suites area, click
. The following page is displayed. Figure 1 Configuring the TLS versions
Table 2 Parameter description Parameter
Versions
- Options are TLS 1.0, TLS 1.1, TLS 1.2, and TLS 1.3.
- Enable only a single version or consecutive versions. For example, you cannot enable TLS 1.0 and TLS 1.2 but disable TLS 1.1.
- Enable at least one version.
Cipher Suite Type
CDN supports cipher suites of multiple strengths and custom cipher suites. For details about the supported cipher suites, see Table 3.
Strong: poor browser compatibility but high security.
Moderate: moderate browser compatibility and security.
Default: strong browser compatibility but low security.
Custom: Customize cipher suites to meet your needs.
NOTE:TLS 1.3 does not support custom cipher suites.
Custom Cipher Suites
Select the required cipher suite as required.
Table 3 Cipher suites supported by CDN OpenSSL Encryption Suite
Strong
Moderate
Default
Custom
ECDHE-ECDSA-AES128-GCM-SHA256
Supported
Supported
Supported
Supported
ECDHE-ECDSA-AES256-GCM-SHA384
Supported
Supported
Supported
Supported
ECDHE-RSA-AES128-GCM-SHA256
Supported
Supported
Supported
Supported
ECDHE-RSA-AES256-GCM-SHA384
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
ECDHE-ECDSA-AES128-SHA256
Supported
Supported
Supported
ECDHE-ECDSA-AES256-SHA384
Supported
Supported
Supported
ECDHE-RSA-AES128-SHA
Supported
Supported
ECDHE-RSA-AES128-SHA256
Supported
Supported
Supported
ECDHE-RSA-AES256-SHA
Supported
Supported
Supported
ECDHE-RSA-AES256-SHA384
Supported
Supported
Supported
DHE-RSA-AES128-SHA
Supported
Supported
Supported
Supported
Supported
Supported
DHE-RSA-AES256-SHA
Supported
Supported
Supported
DHE-RSA-AES256-SHA256
Supported
Supported
Supported
AES128-GCM-SHA256
Supported
Supported
AES256-GCM-SHA384
Supported
Supported
AES128-SHA256
Supported
Supported
AES256-SHA256
Supported
Supported
ECDHE-ECDSA-CHACHA20-POLY1305
Supported
Supported
Supported
Supported
ECDHE-RSA-CHACHA20-POLY1305
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
AES128-SHA
Supported
AES256-SHA
Supported
DES-CBC3-SHA
Supported
RC4-SHA
Supported
- Select TLS versions and cipher suites and click OK.
Relationship Between TLS Versions and Cipher Suites
| OpenSSL Encryption Suite | TLS 1.3 | TLS 1.2 | TLS 1.1 | TLS 1.0 |
| TLS_AES_128_GCM_SHA256 | √ | - | - | - |
| TLS_AES_256_GCM_SHA384 | √ | - | - | - |
| TLS_CHACHA20_POLY1305_SHA256 | √ | - | - | - |
| ECDHE-ECDSA-AES128-GCM-SHA256 | - | Supported | - | - |
| ECDHE-ECDSA-AES256-GCM-SHA384 | - | Supported | - | - |
| ECDHE-RSA-AES128-GCM-SHA256 | - | Supported | - | - |
| ECDHE-RSA-AES256-GCM-SHA384 | - | Supported | - | - |
| ECDHE-ECDSA-AES128-SHA256 | - | Supported | - | - |
| ECDHE-ECDSA-AES256-SHA384 | - | Supported | - | - |
| ECDHE-RSA-AES128-SHA | - | Supported | Supported | Supported |
| ECDHE-RSA-AES128-SHA256 | - | Supported | - | - |
| ECDHE-RSA-AES256-SHA | - | Supported | Supported | Supported |
| ECDHE-RSA-AES256-SHA384 | - | Supported | - | - |
| DHE-RSA-AES256-SHA256 | - | Supported | - | - |
| ECDHE-ECDSA-CHACHA20-POLY1305 | - | Supported | - | - |
| ECDHE-RSA-CHACHA20-POLY1305 | - | Supported | - | - |
| ECDHE-ECDSA-AES128-SHA | - | Supported | √ | √ |
| ECDHE-ECDSA-AES256-SHA | - | Supported | Supported | Supported |
| DES-CBC3-SHA | - | Supported | Supported | Supported |
| RC4-SHA | - | √ | Supported | Supported |
Helpful Links
Modifying the Full Domain Configuration to modify TLS versions
