Origin Protocol
You can configure the protocol used for origin pull.
Precautions
- By default, CDN uses HTTP for origin pulls.
- If you have enabled HTTP/2 and set the origin protocol to Same as user, CDN uses HTTPS/1.1 for origin pull.
- When CDN uses HTTPS for origin pull, the supported TLS version depends on the origin server settings. For example, if the origin server supports TLS 1.1 and TLS 1.2, CDN will also support TLS 1.1 and TLS 1.2 for origin pull.
- Log in to the CDN console.
- In the navigation pane, choose .
- In the domain list, click the target domain name or click Configure in the Operation column.
- Click the Origin Settings tab.
- Click
next to Origin Protocol. Figure 1 Origin protocol
Table 1 Parameters Origin Protocol
Same as user
The origin protocol is the same as the client access protocol. For example, if a client accesses CDN using HTTP, CDN also uses HTTP for origin pull.
HTTP
CDN uses HTTP for origin pull.
HTTPS
CDN uses HTTPS for origin pull.
- Select an origin protocol and click OK.
Helpful Links
- Modifying Origin Server Settings
- Modifying the Full Domain Configuration to modify origin protocol settings
