Updated on 2026-10-21 GMT+08:00
Force Redirect
Requests from clients to CDN PoPs can be forcibly redirected to HTTP or HTTPS.
Force redirect to HTTP: If you do not have high security requirements, use 301/302/307 to forcibly redirect all client requests to HTTP.
Force redirect to HTTPS: If you have set a certificate for your domain name on CDN and you pay more attention to security, use 301/302/307 to forcibly redirect all client requests to HTTPS.
Precautions
  • To use force redirect, configure an HTTPS certificate for your domain name first.
  • If you have configured force redirect to HTTPS, disabling the certificate will also disable force redirect to HTTPS.
  • If you have enabled HTTP/2, force redirect to HTTP does not take effect.
  1. Log in to the CDN console.
  2. In the navigation pane, choose Domains.
  3. In the domain list, click the target domain name. The Overview page is displayed.
  4. In the full configuration directory, click the HTTPS Settings tab.
  5. Click next to Force Redirect.
    Figure 1 Force redirect
    Table 1 Parameter description
    Status
    Whether to enable this function.
    Enabled: Specify whether to redirect requests from clients to HTTP or HTTPS.
    Disabled: Both HTTP and HTTPS requests from clients are supported.
    Protocol
    HTTP: Requests from clients to CDN PoPs are forcibly redirected to HTTP.
    HTTPS: Requests from clients to CDN PoPs are forcibly redirected to HTTPS.
    Redirect Mode
    301
    302
    307
  6. Select a mode and click OK.
Helpful Links
Modifying the Full Domain Configuration to modify force redirect settings
