Updated on 2026-11-18 GMT+08:00
Video Seek
Background
Video seek is mainly used in VOD scenarios. It allows users to seek to a certain position in a video without affecting the playback effect.
  • If video seek is configured, a user client sends a request similar to the following to the server when the user drags the progress bar during video playback:
    http://www.example.com/test.flv?start=50
    In this example, data starting from the 50th byte is returned to the client. If the video has been cached on a CDN PoP, the CDN PoP directly returns the data to the user.
  • Video seek is valid only when Query Parameters is set to Ignore all for MP4 and FLV files. For details, see CDN PoP Cache Rules.
  • Video seek is valid only when your origin server supports range requests.
  • Only MP4 and FLV videos are supported.
Table 1 File formats
File Format
Meta Information
Start Parameter
Example
MP4
The meta information of a video on your origin server must be contained in the file header rather than the file tail.
The start parameter indicates a time. CDN automatically locates the key frame before the time specified by the start parameter if the specified time is not a key frame. The unit is second and decimal places are supported. For example, start=1.01 indicates that the start time is 1.01 seconds.
http://www.example.com/test.mp4?start=50
The playback starts from the 50th second.
FLV
A video on your origin server must contain meta information.
The start parameter indicates a byte. CDN automatically locates the key frame before the byte specified by the start parameter if the specified byte is not a key frame.
http://www.example.com/test.flv?start=500
The playback starts from the 500th byte.
Precautions
  • You have configured a cache rule for FLV and MP4 files and set Query Parameters to Ignore all.
  • If the service type of your domain name is whole site acceleration, this function takes effect only for static resources.
  1. Log in to the CDN console.
  2. In the navigation pane, choose Domains.
  3. In the domain list, click the target domain name. The Overview page is displayed.
  4. In the full configuration directory, click the More Service Configurations tab.
  5. Click next to Video Seek.
    Figure 1 Configuring video seek
  6. (Optional) Enable time-based FLV seek.
    Switch on Time-based FLV Seek, so FLV videos can be sought by time.
    If you enable Time-based FLV Seek, it is valid only when Video Seek is enabled.
  7. (Optional) Configure the start and end parameters.
    • By default, the start parameter is start and the end parameter is end.
    • A parameter can contain up to 64 characters, including letters, digits, and underscores (_).
  8. Click OK.
Helpful Links
Modifying the Full Domain Configuration to modify video seek settings
