Updated on 2025-11-13 GMT+08:00
Origin Request Headers
You can configure HTTP headers in origin pull URLs.
Background
If the requested content is not cached on CDN PoPs, CDN PoPs pull that content from an origin server. You can configure HTTP headers on the CDN console to rewrite header details in origin pull URLs.
HTTP headers are part of an HTTP request or response message that defines the operating parameters of an HTTP transaction.
Precautions
  • This setting only modifies HTTP messages for origin pull through CDN. It does not modify those in an HTTP message that CDN PoPs return to users.
  • A request header cannot have two different values at the same time.
  • If your domain name has special configurations, the origin request headers cannot be configured.
  • You can add up to 10 headers.
  1. Log in to the CDN console.
  2. In the navigation pane, choose Domains.
  3. In the domain list, click the target domain name or click Configure in the Operation column.
  4. Click the Origin Settings tab.
  5. In the Origin Request Headers area, click Add.
  6. Configure the header details.
    • Add: Add a header to CDN to rewrite HTTP headers in user request URLs.
    Figure 1 Adding an origin request header
    Table 1 Parameter description
    Example
    Request Header Operation
    Set
    Add a specific header to an HTTP request of origin pull.
    • If a request URL contains the X-test header and its value is 111, CDN will set X-test to aaa during origin pull.
    • If a request URL does not contain the X-test header, CDN will add X-test and set its value to aaa during origin pull.
    Delete
    Delete the HTTP header that exists in a user request URL.
    • If a request URL contains the X-test header, it will be deleted during origin pull.
    Name
    X-test
    • Enter 1 to 100 characters.
    • Start with a letter and use only letters, digits, and hyphens (-).
    Value
    aaa
    • Enter 1 to 1,000 characters.
    • Use only letters, digits, and these special characters: .-_*#!&+|^~'"/:;,=@?<>${}
    • ${ and } must be used in pairs.
    • Supported variables:
      • ${arg_xxx}: obtains the value of request parameter xxx. xxx can contain letters, digits, hyphens (-), underscores (_), periods (.), and tildes (~). xxx is case sensitive. That is, ${arg_test} and ${arg_TEST} are different.
      • ${http_xxx}: obtains the value of request header xxx. xxx can contain letters, digits, underscores (_), and periods (.).
        • xxx is case insensitive. That is, ${http_test} and ${http_TEST} are the same.
        • To obtain the value of request header xxx using a variable, replace the hyphen (-) with an underscore (_) when configuring the request header. For example, to obtain the value of request header X-CCDN-Test, set this parameter to ${http_X_CCDN_Test}.
      • ${request_method}: obtains the request method.
      • ${host}: obtains the acceleration domain name.
      • ${remote_addr}: obtains the client IP address.
    • You can concatenate variables, such as ${host}and${arg_name}, but you cannot nest them, such as ${${host}}.
    • Edit: Modify the value or operation of a header during origin pull. Click Edit in the Operation column next to a header.
    Figure 2 Editing an origin request header
    Example
    Set
    Delete
    Name
    X-test
    This parameter cannot be modified.
    Value
    aaa
    • Use only letters, digits, and these special characters: .-_*#!&+|^~'"/:;,=@?<>$%{}
      • ${arg_name}: obtains the value of request parameter name (changeable).
      • ${http_name}: obtains the value of request header name (changeable).
    • Delete: Delete the header settings. Click Delete in the Operation column of the request header to be deleted. In the displayed dialog box, select other domain names with the same header to be deleted and click OK.
  7. Click OK.
Examples
Assume that you have configured the following origin request headers for domain name www.example.com:
When a user requests the http://www.example.com/abc.jpg file that is not cached on CDN, CDN pulls that file from the origin server. The X-cdn header will be added and the X-test header will be deleted during origin pull.
  • If your domain name has special configurations, Content-Type, Cache-Control, and Expires cannot be configured.
  • The following request headers can only be modified. You cannot set Request Header Operation to Delete for them.
    Expires
    Content-Disposition
    Content-Type
    Content-Language
    Cache-Control
  • The following standard headers cannot be added, deleted, or modified.
    a_dynamic
    cross-origin-embedder-policy
    origin
    strict-transport-security
    accept
    cross-origin-opener-policy
    ping-from
    te
    accept-ch
    cross-origin-resource-policy
    ping-to
    timing-allow-origin
    accept-charset
    date
    pragma
    tk
    accept-ch-lifetime
    device-memory
    proxy-authenticate
    trailer
    accept-push-policy
    dnt
    proxy-authorization
    transfer-encoding
    accept-ranges
    dpr
    public-key-pins
    upgrade
    accept-signature
    early-data
    public-key-pins-report-only
    upgrade-insecure-requests
    access-control-allow-credentials
    etag
    push-policy
    vary
    access-control-allow-headers
    expect
    range
    via
    access-control-allow-methods
    expect-ct
    referer-policy
    viewport-width
    access-control-allow-origin
    feature-policy
    report-to
    warning
    access-control-expose-headers
    forwarded
    retry-after
    width
    access-control-max-age
    from
    save-data
    www-authenticate
    access-control-request-headers
    host
    sec-fetch-dest
    x-client-ip
    access-control-request-method
    if-match
    sec-fetch-mode
    x-content-type-options
    age
    if-modified-since
    sec-fetch-site
    x-dns-prefetch-control
    allow
    if-none-match
    sec-fetch-user
    x-download-options
    alt-svc
    if-range
    sec-websocket-accept
    x-firefox-spdy
    authorization
    if-unmodified-since
    sec-websocket-extensions
    x-forwarded-for
    clear-site-data
    keep-alive
    sec-websocket-key
    x-forwarded-host
    connection
    large-allocation
    sec-websocket-protocol
    x-frame-options(xfo)
    content-dpr
    last-event-id
    sec-websocket-version
    x-permitted-cross-domain-policies
    content-encoding
    last-modified
    server
    x-pingback
    content-length
    link
    server-timing
    x-powered-by
    content-location
    location
    service-worker-allowed
    x-requested-with
    content-range
    max-age
    signature
    x-robots-tag
    content-security-policy
    max-forwards
    signed-headers
    x-ua-compatible
    content-security-policy-report-only
    nel
    sourcemap
    x-xss-protection
