Updated on 2026-08-04 GMT+08:00
Smart Compression
When smart compression is enabled, CDN automatically compresses your static files. This saves you a lot of bandwidth by reducing file size and speeds up file transfer. Smart compression includes gzip compression and Brotli compression. The performance of Brotli compression is 15% to 25% higher than that of gzip compression.
Precautions
  • Starting in late January 2025, CDN will change the default file size for compression. If you do not specify a file size when enabling smart compression:
    • Before the change, all files are compressed by default.
    • After the change, files whose size ranges from 0 MB to 30 MB are compressed by default.
  • Do not enable this function if MD5 verification has been configured for your origin server. When CDN compresses static files, the MD5 value is changed. As a result, the MD5 value of the compressed file is different from that of the file on the origin server.
  • Some browsers do not support Brotli compression. Check supported browsers on this website.
  • You cannot enable smart compression for domain names with special configurations.
  • If both gzip and Brotli compression are enabled, Brotli compression is preferentially performed.
  • General image files (such as PNG, JPG, and JPEG) and video files (such as MP4, AVI, and WMV) have already been compressed. Therefore, you do not need to enable smart compression (gzip or Brotli) for these files.
  1. Log in to the CDN console.
  2. In the navigation pane, choose Domains.
  3. In the domain list, click the target domain name.
  4. Click the Advanced Settings tab.
  5. Click next to Smart Compression.
    Figure 1 Smart compression
    Table 1 Parameter description
    Status
    Turn on or off the switch.
    Compression Mode
    Gzip or Brotli compression. If both are selected, Brotli compression is used.
    Format
    Enter file name extensions and multipurpose internet mail extensions (MIME).
    • A single extension contains up to 50 characters and all extensions contain up to 2,000 characters. Separate extensions by semicolon (;).
    • If this parameter is left empty, the following default extensions are used:
      • File name extensions: .js;.html;.css;.xml;.json;.shtml;.htm
      • MIME: text/xml;text/plain;text/javascript;text/html;text/css;image/tiff;image/svg+xml;application/xml;application/x-javascript;application/rss+xml;application/json;application/javascript
    File Size
    Select Enabled and specify a file size range. Files in this range will be compressed.
    • The file size range is 0 MB to 30 MB.
    • If no range is specified, files no larger than 30 MB will be compressed.
  6. Select a compression method, specify formats of files to compress, and click OK.
Helpful Links
Modifying the Full Domain Configuration to modify smart compression settings
