Help Center/
Content Delivery Network/
User Guide/
Cache Prefetch and Purge/
Viewing Task Progresses
Updated on 2025-06-06 GMT+08:00
After a cache purge or prefetch task is submitted, you can view the task status on the Task Progress tab page.
- Log in to Huawei Cloud console. Choose .
The CDN console is displayed.
- In the navigation pane, choose .
- Click the Task Progress tab to check the task status.
You can view the failure cause of a failed task.
Figure 1 Purge and prefetch history- On the Task Progress tab page, you can view the status of cache purge and prefetch tasks over the last 15 days.
- You can also query the cache purge and prefetch records of the last 15 days on the URL Query tab page.
Parent topic: Cache Prefetch and Purge
