Updated on 2026-07-21 GMT+08:00
OBS Authorization
If you use a Huawei Cloud OBS private bucket as the origin server and want to use OBS Pull Authentication, enable OBS authorization so that CDN can pull content from your private bucket.
Do not delete the agency for authorizing CDN to access OBS. Otherwise, CDN cannot pull resources from OBS private buckets.
By default, an account administrator has all permissions. You do not need to add permissions when configuring an agency as an account administrator. IAM users can enable OBS authorization only when they have the required permissions.
To use role- or policy-based authorization, the IAM users must have the following permissions:
  1. IAM permissions
    • Listing agencies: iam:agencies:listAgencies
    • Creating an agency: iam:agencies:createAgency
    • Granting permissions to an agency for a region-specific project: iam:permissions:grantRoleToAgencyOnProject
  2. CDN permissions
    • Changing the billing option: cdn:configuration:modifyChargeMode
    • Granting CDN read-only permissions: CDN ReadOnlyAccess
To use identity policy-based authorization, the IAM users must have the following permissions:
  • Querying permissions: iam:roles:list
  • Granting permissions to an agency for a region-specific project: iam:agencies:grantRoleOnProject
Precautions
  1. Log in to the CDN console.
  2. In the navigation pane, choose Domains.
  3. In the upper right corner of the Domains page, click Enable OBS Authorization.
Figure 1 OBS authorization
  1. Click Authorize. The system creates an agency named CDNAccessPrivateOBS for you on the IAM console. CDN now has the read-only permission to access your private OBS buckets.
If files in your OBS bucket are encrypted using KMS, assign the permissions for viewing KMS keys and encrypting DEKs to the CDNAccessPrivateOBS agency so that CDN can read and accelerate delivery of the encrypted files.
  1. (Optional) Assign the permissions for viewing KMS keys and encrypting data keys to the CDNAccessPrivateOBS agency.
    1. Log in to the Huawei Cloud console. Choose Service List > Management & Government > Identity and Access Management to access the IAM console.
    2. In the navigation pane, choose Agencies.
    3. On the Agencies page, click Authorize in the Operation column of the row containing CDNAccessPrivateOBS.
      The Select Policy/Role page is displayed.
    4. Click Create Policy in the upper right corner and set the parameters as follows:
      • Policy Name: Enter a custom name.
      • Policy View: Select Visual editor.
      • Policy Content:
        • Select Allow.
        • Select service: Select Key Management Service (KMS).
        • Select action: To use role or policy-based authorization, select kms:cmk:get and kms:dek:crypto. To use identity policy-based authorization, select kms:cmk:get and kms:cmk:encryptDataKey.
        • Resources: Select All.
    5. Click Next.
    6. Select the policy created in the previous step and click Next.
    7. Set Scope to Region-specific projects and select the region of the OBS bucket.
    8. Click OK.
