Updated on 2026-07-21 GMT+08:00
Using CTS to Audit CDN
Cloud Trace Service (CTS) records operations on cloud resources in your account. You can use the logs to perform security analysis, track resource changes, audit compliance, and locate faults.
Enabling CTS
A tracker will be automatically created after CTS is enabled. All traces recorded by CTS are associated with a tracker. Currently, only one tracker can be created for each account.
For details about how to enable CTS, see CTS Overview.
CDN Operations Recorded by CTS
Table 1 CDN operations that can be recorded by CTS
Operation
createDomain
Creating a domain name
updateDomain
Updating a domain name
Configuring range requests
Configuring redirect from origin
Configuring an IP ACL
Configuring the host header
Configuring the origin server
Configuring an HTTPS certificate
Configuring cache rules
Configuring HTTP headers
deleteDomain
Removing a domain name
enableDomain
Enabling domain names
disableDomain
Disabling domain names
updateOrigin
Configuring an origin server
updateOriginHost
Configuring a host header
createRefer
Creating a referer rule
createCertificate
Configuring a domain certificate
createCacheRule
Creating a cache rule
createRefreshTask
Creating a cache purge task
createPreheatingTask
Creating a cache prefetch task
createTags
Adding a tag
batchDeleteTags
Deleting tags in a batch
updateDomainRule
Modifying a rule in the rules engine
deleteDomainRule
Deleting a rule from the rules engine
updateDomainRule
Modifying rules in the rules engine in a batch
updateDomainRule
Updating all rules in the rules engine
updateDomainMultiCertificates
Configuring HTTPS for domain names in a batch
updatePrivateBucketAccess
Modifying the status of OBS private bucket access
batchCopyDomain
Configuring domain names in a batch
Viewing CTS Traces
After you enable CTS, the system starts to record CDN operations. You can view operations of the past seven days on the CTS console. For details, see Querying Real-Time Traces.
Disabling CTS
You can disable trackers on the CTS console. After a tracker is disabled, the system will stop recording operations, but you can still view historical records. For details about how to disable a tracker, see Disabling or Enabling a Tracker.
