Authorizing and Associating an Enterprise Project
Huawei Cloud Enterprise Management allows unified cloud resource management by enterprise project. You can manage resources and personnel in enterprise projects, and assign one or more user groups to manage enterprise projects. You can create CDN enterprise projects on the Enterprise Management console to manage your domain resources in a centralized manner.
Creating an Enterprise Project
To create a CDN enterprise project:
- On the Enterprise Management console, create an enterprise project based on your enterprise's requirements. For example, you can create enterprise projects based on the service types of the CDN acceleration domain names. For details, see Creating an Enterprise Project.
- After an enterprise project is created, you can migrate your domain name resources to a specified enterprise project. For details, see Supported Cloud Services.
- An enterprise project named default is created by default. This project is used to manage any resources that are not allocated to a specific enterprise project.
- Migrating an acceleration domain name between enterprise projects does not affect the acceleration service.
Enterprise Project Authorization
After an enterprise project is created and CDN resources are migrated to the enterprise project, you can add existing user groups and set user group permission policies for the enterprise project based on site requirements. Without these policies, user group members will be unable to access or operate the CDN domain resources in the enterprise project. For details about how to set user group permission policies, see Permissions Management.
