IP Address Check
If the content shown on the access page of the acceleration domain name is abnormal, you can use the PoP IP address checking tool to check whether the specified IP address is the IP address of a Huawei Cloud CDN PoP. In this way, you can know whether the abnormality is caused by the carrier network or other reasons.
- If the check result shows that the IP address is not that of a Huawei Cloud CDN PoP, the problem may lie in the carrier network. In this case, contact your carrier.
 - If the IP address belongs to a Huawei Cloud CDN PoP, rectify the fault by referring to Troubleshooting.
- Log in to the CDN console.
 - In the navigation pane, choose .
    Figure 1 Checking PoP IP addresses
     - Enter the IP addresses to be checked in the IP Addresses text box.
Enter each IPv4 or IPv6 address on separate lines. A maximum of 20 IP addresses can be checked at a time.
 - Click Check.
After the diagnosis is complete, the system displays the results in the list.
