Updated on 2026-10-21 GMT+08:00
HTTP/2
Background
HTTP/2 is a next-generation hypertext transfer protocol. It reduces the TCP handshake delay, reduces the packet header transmission volume, and improves transmission efficiency. Addresses starting with http:// can use only the HTTP/1.x protocol, and those starting with https:// support HTTP/2.
HTTP/2 works best in high-concurrency scenarios of small files. It uses TCP multiplexing to reduce the average processing latency of each request (except the first request, skipping repeated TCP and SSL handshakes). In poor networks, HTTP/2 suffers from TCP-level head-of-line blocking. It relies on a single TCP connection for all requests, which demands ordered packet delivery. If one TCP packet is lost, the entire TCP connection is blocked, and all concurrent HTTP/2 streams need to wait until the retransmission completes. Unlike HTTP/2, HTTP/1.1 lets browsers open several TCP connections, so losing one packet does not block other connections.
Scenarios where HTTP/2 is recommended: high-concurrency scenarios of small files and API calling.
Scenarios where HTTP/2 is not recommended: mixed loading of large and small files. If a packet is lost during the transmission of a large file, the loading of small files slows down, affecting the first screen performance.
An HTTPS certificate has been configured. For details, see Configuring an HTTPS Certificate.
Precautions
  • Disabling the HTTPS certificate will disable HTTP/2.
  • After configuring the HTTPS certificate, wait about 5 minutes for the configuration to complete and then enable HTTP/2.
  • If you set two certificates for a domain name, HTTP/2 takes effect only for the international certificate.
Protocol Advantages
HTTP/1.1 is the current mainstream protocol used on the Internet. HTTP/2 outperforms HTTP/1.1 and keeps the syntax of HTTP/1.1.
HTTP/2 outperforms HTTP/1.1 in the following aspects:
  • Binary framing
    HTTP/2 uses binary format to transfer data, while HTTP/1.1 is a text-based protocol. Binary format is more advantageous in resolving and optimizing the protocol, and it raises the efficiency of data transfer.
  • Header field compression
    HTTP/2 uses HPACK to compress header fields during transmission. The client and server maintain header tables to track and store previously transmitted headers. When a header field is repeated, only its index needs to be transmitted, allowing the previously transmitted header to be retrieved from the header table instead of resending the full header.
    HTTP/1.1 requests carry a significant amount of redundant header information, resulting in unnecessary bandwidth consumption. By compressing header fields, HTTP/2 reduces bandwidth usage and traffic overhead.
  • Multiplexing
    HTTP/2 multiplexes multiple requests or responses over a single TCP connection, while HTTP/1.1 establishes a TCP connection for each request or response in order. By sending requests concurrently, HTTP/2 lessens the pressure on server connections and alleviates the network blocking problem.
  1. Log in to the CDN console.
  2. In the navigation pane, choose Domains.
  3. In the domain list, click the target domain name. The Overview page is displayed.
  4. In the full configuration directory, click the HTTPS Settings tab.
  5. Switch on HTTP/2.
Helpful Links
Modifying the Full Domain Configuration to modify HTTP/2 settings
