Dameng Database Link Parameters
Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
| Parameter | Description | Example Value |
| Name | Link name, which should be defined based on the data source type, so it is easier to remember what the link is for | dm_link |
| Database Server | IP address or domain name of the database to connect. Use semicolons (;) to separate multiple values. | 192.168.0.1;192.168.0.2 |
| Port | Port of the database to connect | The port number varies depending on the database. |
| Database Name | Name of the database to connect | dbname |
| Username | Username used for accessing the database This account must have the permissions required to read and write data tables and metadata. | cdm |
| Password | Password of the user | - |
| SSL Encryption | Whether to connect to the database using SSL | No |
| Keystore certificate | Keystore certificate used for SSL authentication. Only the .keystore format is supported. No certificate can be uploaded on the link configuration page. To upload a certificate, click Manage Certificates on the Links page and then click Upload Certificate. | - |
| Keystore Password | Password of the keystore certificate file. This parameter is mandatory if you set Keystore certificate. | - |
| Reference Sign | (Optional) Delimiter between the names of the referenced tables or columns. For details, see the product documentation of the corresponding database. | ' |
| Driver Version | Select a driver version that adapts to the database type. | - |
| Fetch Size | (Optional) Displayed when you click Show Advanced Attributes. Number of rows obtained by each request. Set this parameter based on the data source and the job's data size. If the value is either too large or too small, the job may run for a long time. | 1000 |
| Link Attributes | (Optional) Click Add to add the JDBC connector attributes of multiple specified data sources. For details, see the JDBC connector document of the corresponding database. | sslmode=require |
| Link Secret Attributes | (Optional) Custom secret attributes of the link. The attributes are in the following format: key1=value1&...&keyN=valueN. They are encrypted, so historical values are not displayed when you edit the attributes again. | - |
