On this page
Show all
Oracle Database Link Parameters
Updated on 2024-11-20 GMT+08:00
Table 1 lists the parameters for a link to an Oracle database.
Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
Table 1 Oracle database link parameters
Example Value
Name
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for
oracle_link
Database Server
IP address or domain name of the database to connect
192.168.0.1
Port
Port of the database to connect
Default port: 1521
Connection Type
Oracle database connection type. The following options are available:
  • Service Name: Use SERVICE_NAME to connect to the Oracle database.
  • SID: Use SID to connect to the Oracle database.
SID
Instance Name
Oracle instance ID, which is used to differentiate databases by instances. This parameter is available only when Connection Type is set to SID.
dbname
Database Name
Name of the database to connect This parameter is available only when Connection Type is set to Service Name.
dbname
Username
Username used for accessing the database This account must have the permissions required to read and write data tables and metadata.
cdm
Password
Password of the username
Use Agent
The agent function will be unavailable soon and does not need to be configured.
Agent
Oracle Version
Oracle database version. This parameter is available only for Oracle links. If java.sql.SQLException: Protocol violation is displayed, select another version.
Later than 12.1
Reference Sign
(Optional) Delimiter between the names of the referenced tables or columns. For details, see the product documentation of the corresponding database.
Driver Version
Different types of relational databases adapt to different drivers. For details, see How Do I Obtain a Driver?
Fetch Size
(Optional) Displayed when you click Show Advanced Attributes.
Number of rows obtained by each request. Set this parameter based on the data source and the job's data size. If the value is either too large or too small, the job may run for a long time.
A migration from the Oracle to DWS database may time out due to a long data write duration in the DWS database. In this case, reduce the value of Fetch Size for the Oracle database.
1000
Commit Size
Number of rows submitted in a batch
10000
Link Attributes
(Optional) Click Add to add the JDBC connector attributes of multiple specified data sources. For details, see the JDBC connector document of the corresponding database.
The following are some examples:
  • socketTimeout: JDBC connection timeout duration, in milliseconds
  • mysql.bool.type.transform: whether to parse tinyint(1) to a Boolean value during data reading from a MySQL database. The default value is true.
Link Secret Attributes
Custom secret attributes of the link
sk=09fUgD5WOF1L6f
