Supported Data Sources (24.4.x and 2.10.0.400)
- Table/File migration in the import of data into a data lake or migration of data to the cloud. For details, see Data Sources Supported by Table/File Migration.
- Entire DB migration in the import of data into a data lake or migration of data to the cloud. For details, see Supported Data Sources in Entire DB Migration.
This section describes the data sources supported by CDM clusters of version 24.4.x and 2.10.0.400. The supported data sources vary depending on the CDM cluster version.
Table/File migration can migrate data in tables or files.
| Category | Source | Destination | Description |
| Data warehouse | Data Warehouse Service (DWS) |
| The DWS physical machine management mode is not supported. Only non-security CSS clusters can be migrated, that is, clusters whose security mode is disabled. |
| Data Lake Insight (DLI) |
| Recommended MongoDB version: 4.2 You must have the SELECT permission (for querying tables) on all fields of the DLI data source. | |
| MRS ClickHouse | Data warehouse: MRS ClickHouse and DLI | ||
| Doris | Data warehouses: Doris | MRS clusters whose Kerberos encryption type is aes256-sha2,aes128-sha2 are not supported, and only MRS clusters whose Kerberos encryption type is aes256-sha1,aes128-sha1 are supported. | |
| Hadoop | MRS HDFS |
| MRS HBase | |||
| MRS Hive |
| MRS Hudi |
| Apache HBase |
| Apache Hive | |||
| Apache HDFS | |||
| Object storage | Object Storage Service (OBS) |
| File system | FTP |
| SFTP | |||
| HTTP | Hadoop: MRS HDFS | ||
| Relational database | RDS for MySQL |
| RDS for SQL Server |
| RDS for PostgreSQL | |||
| MySQL |
| PostgreSQL | |||
| Oracle | |||
| Microsoft SQL Server |
| NoSQL | Distributed Cache Service (DCS) |
| NoSQL cannot serve as the destination. For how to migrate data from Redis to DCS, see Migrating Data from Self-Hosted Redis to DCS. |
| Redis | |||
| MongoDB | |||
| Message system | Data Ingestion Service (DIS) | In OBT: Cloud Search Service (CSS) | The message system cannot serve as the destination. Only non-security CSS clusters can be migrated, that is, clusters whose security mode is disabled. |
| Apache Kafka | |||
| DMS Kafka | |||
| MRS Kafka |
| Search | Elasticsearch |
| Only the non-security mode is supported. Only non-security CSS clusters can be migrated, that is, clusters whose security mode is disabled. |
| In OBT | CloudTable HBase |
| Only non-security CSS clusters can be migrated, that is, clusters whose security mode is disabled. You are advised to use Logstash to import data to CSS. For details, see Using Logstash to Import Data to Elasticsearch. | |
| SAP HANA |
| SAP HANA data sources have the following restrictions:
| FusionInsight HDFS |
| FusionInsight HBase | |||
| FusionInsight Hive | |||
| Database shard |
| Database shards cannot serve as the destination. Only non-security CSS clusters can be migrated, that is, clusters whose security mode is disabled. | |
| Dameng database |
| ShenTong | Hadoop: MRS Hive and MRS Hudi | - | |
| Document Database Service (DDS) | Hadoop: MRS HDFS, MRS HBase, and MRS Hive | - | |
| RestFul API | Data warehouse: DWS Currently, only CDM clusters running 24.4.x & 2.10.0.400 and later versions support this link. | - | |
| GBASE8S |
| GBASE8A |
In the preceding table, the non-cloud data sources, such as MySQL, include on-premises MySQL, MySQL built on ECSs, or MySQL on the third-party cloud.
Entire DB migration is used when an on-premises data center or a database created on an ECS needs to be synchronized to a database service or big data service on the cloud. It is suitable for offline database migration but not online real-time migration.
Table 2 lists the data sources supporting entire DB migration using CDM.
| Category | Data Source | Read | Write | Description |
| Data warehouse | Data Warehouse Service (DWS) | Supported | Supported | - |
| Hadoop (available only for local storage, and not for storage-compute decoupling, Ranger, or ZooKeeper for which SSL is enabled) | MRS HBase | Supported | Supported | Entire DB migration only to MRS HBase Recommended versions:
| MRS Hive | Supported | Supported | Entire DB migration only to a relational database 2.x versions are not supported. The following versions are recommended:
| Apache HBase | Supported | Not supported | Recommended versions:
| Apache Hive | Supported | Not supported | Entire DB migration only to a relational database 2.x versions are not supported. The following versions are recommended:
| MRS Hudi | Supported | Supported | Supported only by local storage and in storage-compute decoupling scenarios 2.x versions are not supported. The following versions are recommended:
| Relational database | RDS for MySQL | Supported | Supported | Migration from OLTP to OLTP is not supported. In this scenario, you are advised to use the Data Replication Service (DRS). |
| RDS for PostgreSQL | Supported | Supported | ||
| RDS for SQL Server | Supported | Supported | ||
| MySQL | Supported | Not supported | ||
| PostgreSQL | Supported | Not supported | ||
| Microsoft SQL Server | Supported | Not supported | ||
| Oracle | Supported | Not supported | ||
| NoSQL | Distributed Cache Service (DCS) | Not supported | Supported | Only migration from MRS to DCS is supported. |
| In OBT | CloudTable HBase | Supported | Supported | - |
| FusionInsight HBase | Supported | Not supported | Recommended versions:
| FusionInsight Hive | Supported | Not supported | Entire DB migration only to a relational database 2.x versions are not supported. The following versions are recommended:
| SAP HANA | Supported | Not supported |
| Dameng database | Supported | Not supported | Only to DWS and Hive | |
| Document Database Service (DDS) | Supported | Supported | Only migration between DDS and MRS is supported. |
