DWS Link Parameters
Table 1 describes the DWS link parameters.
Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
| Parameter | Description | Example Value |
| Name | Link name, which should be defined based on the data source type, so it is easier to remember what the link is for | dws_link |
| Database Server | IP address or domain name of the database to connect Click Select next to the text box to obtain the list of instances. | 192.168.0.1 |
| Port | Port of the database to connect | The port number varies depending on the database. |
| Database Name | Name of the database to connect | dbname |
| Username | Username used for accessing the database. This user must have the permissions to read and write data tables and metadata. | cdm |
| Password | Password of the user | - |
| Use Agent | The agent function will be unavailable soon and does not need to be configured. | - |
| Reference Sign | (Optional) Delimiter between the names of the referenced tables or columns. For details, see the product documentation of the corresponding database. | " |
| Fetch Size | (Optional) Displayed when you click Show Advanced Attributes. Number of rows obtained by each request. Set this parameter based on the data source and the job's data size. If the value is either too large or too small, the job may run for a long time. | 1000 |
| SSL Encryption | Whether to connect to the data warehouse in SSL mode | Yes NOTE: To enable SSL encryption, you must ensure that it is enabled for GaussDB(DWS). |
| Link Attributes | (Optional) Displayed when you click Show Advanced Attributes. You can click Add to add custom attributes for the link. The following are some examples:
| Link Secret Attributes | (Optional) Displayed when you click Show Advanced Attributes. Custom secret attributes of the link | sk=09fUgD5WOF1L6f |
