Supported Data Types
To ensure that data is completely imported to the migration destination, correctly configure field mappings based on data types supported for different data sources. For details, see Table 1.
| Data Connection Type | Data Type |
| MySQL | |
| SQL Server | |
| Oracle | |
| PostgreSQL | |
| ShenTong | |
| SAP HANA | |
| DWS | |
| Dameng | |
| DLI | |
| Elasticsearch/Cloud Search Service (CSS) | Data Types Supported in Elasticsearch/CSS Database Migration |
Data Types Supported in MySQL Database Migration
When the source end is a MySQL database and the destination end is a Hive or DWS database, the following data types are supported:
| Category | Type | Description | Storage Format Example | Hive | DWS |
| Character string | CHAR(M) | A fixed-length string of 1 to 255 characters, for example, CHAR(5). The string is padded to a specified length with spaces on the right. The length limit is not mandatory. It is set to 1 by default. | 'a' or 'aaaaa' | CHAR | CHAR |
| VARCHAR(M) | A variable-length string of 1 to 255 characters (more than 255 characters for MySQL of a later version), for example, VARCHAR(25). When creating a field of the VARCHAR type, you must define the length. | 'a' or 'aaaaa' | VARCHAR | VARCHAR | |
| Value | DECIMAL(M,D) | Uncompressed floating-point numbers cannot be unsigned. In unpacking decimals, each decimal corresponds to a byte. Defining the number of display lengths (M) and decimals (D) is required. NUMERIC is the synonym of DECIMAL. | 52.36 | DECIMAL | When D is 0, it corresponds to BIGINT. When D is not 0, it corresponds to NUMBERIC. |
| NUMBERIC | Same as DECIMAL | - | DECIMAL | NUMBERIC | |
| INTEGER | An integer of normal size that can be signed. If the value is signed, it ranges from -2147483648 to 2147483647. If the value is unsigned, the value ranges from 0 to 4294967295. Up to 11-bit width can be specified. | 5236 | INT | INTEGER | |
| INTEGER UNSIGNED | Unsigned form of INTEGER | - | BIGINT | INTEGER | |
| INT | Same as INTEGER | 5236 | INT | INTEGER | |
| INT UNSIGNED | Same as INTEGER UNSIGNED | - | BIGINT | INTEGER | |
| BIGINT | A large integer that can be signed. If the value is signed, it ranges from -9223372036854775808 to 9223372036854775807. If the value is unsigned, the value ranges from 0 to 18446744073709551615. Up to 20-bit width can be specified. | 5236 | BIGINT | BIGINT | |
| BIGINT UNSIGNED | Unsigned form of BIGINT | - | BIGINT | BIGINT | |
| MEDIUMINT | A medium-sized integer that can be signed. If the value is signed, it ranges from -8388608 to 8388607. If the value is unsigned, it ranges from 0 to 16777215, and you can specify a maximum of 9-bit width. | -128 to 127 | INT | INTEGER | |
| MEDIUMINT UNSIGNED | Unsigned form of MEDIUMINT | - | BIGINT | INTEGER | |
| TINYINT | A very small integer that can be signed. If signed, the value ranges from -128 to 127. If unsigned, the value ranges from 0 to 255, and you can specify a maximum of 4-bit width. | 100 | TINYINT | SMALLINT | |
| TINYINT UNSIGNED | Unsigned form of TINYINT | - | TINYINT | SMALLINT | |
| BOOL | The bool of MySQL is tinyint(1). | -128, 127 | SMALLINT | BYTEA | |
| SMALLINT | A small integer that can be signed. If the value is signed, it ranges from -32768 to 32767. If unsigned, the value ranges from 0 to 65535, and you can specify a maximum of 5-bit width. | 9999 | SMALLINT | SMALLINT | |
| SMALLINT UNSIGNED | Unsigned form of SMALLINT | - | INT | SMALLINT | |
| REAL | Same as DOUBLE | - | DOUBLE | - | |
| FLOAT(M,D) | Unsigned floating-point numbers cannot be used. The display length (M) and number of decimal places (D) can be specified. This is not mandatory, and the default value is 10,2. In the preceding information, 2 indicates the number of decimal places and 10 indicates the total number of digits (including decimal places). The decimal precision can reach 24 floating points. | 52.36 | FLOAT | FLOAT4 | |
| DOUBLE(M,D) | Unsigned double-precision floating-point numbers cannot be used. The display length (M) and number of decimal places (D) can be specified. This is not mandatory. The default value is 16,4, where 4 is the number of decimal places. The decimal precision can reach 53-digit. REAL is a synonym of DOUBLE. | 52.36 | DOUBLE | FLOAT8 | |
| DOUBLE PRECISION | Similar to DOUBLE | 52.3 | DOUBLE | FLOAT8 | |
| Bit | BIT(M) | Stored bit type value. BIT(M) can store up to M bits of values, and M ranges from 1 to 64. | B'1111100' B'1100' | TINYINT | BYTEA |
| Time and date | DATE | The value is in the YYYY-MM-DD format and ranges from 1000-01-01 to 9999-12-31. For example, December 30, 1973 will be stored as 1973-12-30. | 1999-10-01 | DATE | TIMESTAMP |
| TIME | Stores information about the hour, minute, and second. | '09:10:21' or '9:10:21' | Not supported (string) | TIME | |
| DATETIME | The date and time are in the YYYY-MM-DD HH:MM:SS format and range from 1000-01-01 00:00:00 to 9999-12-31 23:59:59. For example, 3:30 p.m. on December 30, 1973 will be stored as 1973-12-30 15:30:00. | '1973-12-30 15:30:00' | TIMESTAMP | TIMESTAMP | |
| TIMESTAMP | Timestamp type. Timestamp between midnight on January 1, 1970 and a time point in 2037. Similar to the DATETIME format (YYYYMMDDHHMMSS), except that no hyphen is required. For example, 3:30 p.m. December 30, 1973 will be stored as 19731230153000. | 19731230153000 | TIMESTAMP | TIMESTAMP | |
| YEAR(M) | The year is stored in 2-digit or 4-digit number format. If the length is specified as 2 (for example, YEAR(2)), the year ranges from 1970 to 2069 (70 to 69). If the length is specified as 4, the year ranges from 1901 to 2155. The default length is 4. | 2000 | Not supported (string) | Not supported | |
| Multimedia (binary) | BINARY(M) | The number of bytes is M. The length of a variable-length binary string ranges from 0 to M. M is the value length plus 1. | 0x2A3B4058 (binary data) | Not supported | BYTEA |
| VARBINARY(M) | The number of bytes is M. A fixed binary string with a length of 0 to M. | 0x2A3B4059 (binary data) | Not supported | BYTEA | |
| TEXT | The maximum length of the field is 65535 characters. TEXT is a "binary large object" and is used to store large binary data, such as images or other types of files. | 0x5236 (binary data) | Not supported | Not supported | |
| TINYTEXT | A binary string of 0 to 255 bytes in short text | - | - | Not supported | |
| MEDIUMTEXT | A binary string of 0 to 167772154 bytes in medium-length text | - | - | Not supported | |
| LONGTEXT | A binary string of 0 to 4294967295 bytes in large-length text | - | - | Not supported | |
| BLOB | The maximum length of the field is 65535 characters. BLOB is a "binary large object" and is used to store large binary data, such as images or other types of files. BLOB is case-sensitive. | 0x5236 (binary data) | Not supported | Not supported | |
| TINYBLOB | A binary string of 0 to 255 bytes in short text | - | Not supported | Not supported | |
| MEDIUMBLOB | A binary string of 0 to 167772154 bytes in medium-length text | - | Not supported | Not supported | |
| LONGBLOB | A binary string of 0 to 4294967295 bytes in large-length text | 0x5236 (binary data) | Not supported | Not supported | |
| Special type | SET | SET is a string object that can have no or multiple values. The values come from the allowed column of values specified when the table is created. When specifying the SET column values that contain multiple SET members, separate the members with commas (,). The SET member value cannot contain commas (,). | - | - | Not supported |
| JSON | - | - | Not supported | Not supported (TEXT) | |
| ENUM | When an ENUM is defined, a list of its values is created, which are the items that must be used for selection (or NULL). For example, if you want a field to contain "A", "B", or "C", you can define an ENUM ("A", "B", or "C"). Only these values (or NULL) can be used to fill in the field. | - | Not supported | Not supported |
Data Types Supported in Oracle Database Migration
When the source end is an Oracle database and the destination end is a Hive or DWS database, the following data sources are supported:
| Category | Type | Description | Hive | DWS |
| Character string | char | Fixed-length character string, which is padded with spaces to reach the maximum length. | CHAR | CHAR |
| nchar | Fixed-length character string contains data in Unicode format. | CHAR | CHAR | |
| varchar2 | Synonym of VARCHAR. It is a variable-length string, unlike the CHAR type, which does not pad the field or variable to reach its maximum length with spaces. | VARCHAR | VARCHAR | |
| nvarchar2 | Variable-length character string contains data in Unicode format. | VARCHAR | VARCHAR | |
| Value | number | Stores numbers with a precision of up to 38 digits. | DECIMAL | NUMERIC |
| binary_float | 2-bit single-precision floating point number | FLOAT | FLOAT8 | |
| binary_double | 64-bit double-precision floating point number | DOUBLE | FLOAT8 | |
| long | A maximum of 2 GB character data can be stored. | Not supported | Not supported | |
| Time and date | date | 7-byte date/time data type, including seven attributes: century, year in the century, month, day in the month, hour, minute, and second. | DATE | TIMESTAMP |
| timestamp | 7-byte or 11-byte fixed-width date/time data type that contains decimals (seconds) | TIMESTAMP | TIMESTAMP | |
| timestamp with time zone | 3-byte timestamp, which supports the time zone. | TIMESTAMP | TIME WITH TIME ZONE | |
| timestamp with local time zone | 7-byte or 11-byte fixed-width date/time data type. Time zone conversion occurs when data is inserted or read. | TIMESTAMP | Not supported (TEXT) | |
| interval year to month | 5-byte fixed-width data type, which is used to store a time segment. | Not supported | Not supported (TEXT) | |
| interval day to second | 11-byte fixed-width data type, which is used to store a time segment. The time segment is stored in days/hours/minutes/seconds. The value can also contain nine decimal places (seconds). | Not supported | Not supported (TEXT) | |
| Multimedia (binary) | raw | A variable-length binary data type. Character set conversion is not performed for data stored in this data type. | Not supported | Not supported |
| long raw | Stores up to 2 GB binary information. | Not supported | Not supported | |
| blob | A maximum of 4 GB data can be stored. | Not supported | Not supported | |
| clob | In Oracle 10g and later versions, a maximum of (4 GB) x (database block size) bytes of data can be stored. CLOB contains the information for which character set conversion is to be performed. This data type is ideal for storing plain text information. | String | Not supported | |
| nclob | This type can store a maximum of 4 GB data. When the character set is converted, this type is affected. | Not supported | Not supported | |
| bfile | An Oracle directory object and a file name can be stored in the database column, and the file can be read through the Oracle directory object and file name. | Not supported | Not supported | |
| Others | rowid | It is the address of a row in the database table. It is 10 bytes long. | Not supported | Not supported |
| urowid | It is a common row ID and does not have a fixed rowid table. | Not supported | Not supported |
Data Types Supported in SQL Server Database Migration
When the source end is a SQL Server database and the destination end is a Hive, Oracle or DWS database, the following data sources are supported:
| Category | Type | Description | Hive | DWS | Oracle |
| String data type | char | Fixed-length character string, which is padded with spaces to reach the maximum length. | CHAR | CHAR | CHAR |
| nchar | Fixed-length character string contains data in Unicode format. | CHAR | CHAR | CHAR | |
| varchar | A variable-length string consists of 1 to 255 characters (more than 255 characters for MySQL of a later version). Example: VARCHAR(25). When creating a field of the VARCHAR type, you must define the length. | VARCHAR | VARCHAR | VARCHAR | |
| nvarchar | Stores variable-length Unicode character data, similar to varchar. | VARCHAR | VARCHAR | VARCHAR | |
| Numeric data type | int | int is stored in four bytes, where one binary bit represents a sign bit, and the other 31 binary bits represent a length and a size, and may represent all integers ranging from –231 to 231 – 1. | INT | INTEGER | INT |
| bigint | bigint is stored in eight bytes, where one binary bit represents a sign bit, and the other 63 binary bits represent a length and a size, and may represent all integers ranging from –263 to 263 – 1. | BIGINT | BIGINT | NUMBER | |
| smallint | Data of the smallint type occupies two bytes of storage space. One binary bit indicates a positive or negative sign of an integer value, and the other 15 binary bits indicate a length and a size, and may represent all integers ranging from –215 to 215. | SMALLINT | SMALLINT | NUMBER | |
| tinyint | Tinyint data occupies one byte of storage space and can represent all integers ranging from 0 to 255. | TINYINT | TINYINT | NUMBER | |
| real | The value can be a positive or negative decimal number. | DOUBLE | FLOAT4 | NUMBER | |
| float | The number of digits (in scientific notation) of the mantissa of a float value, which determines the precision and storage size | FLOAT | FLOAT8 | binary_float | |
| decimal | Numeric data type with fixed precision and scale | DECIMAL | NUMERIC | NUMBER | |
| numeric | Stores zero, positive, and negative fixed point numbers. | DECIMAL | NUMERIC | NUMBER | |
| Date and time data type | date | Stores date data represented by strings. | DATE | TIMESTAMP | DATE |
| time | Time of a day, which is recorded in the form of a character string. | Not supported (string) | TIME | Not supported | |
| datetime | Stores time and date data. | TIMESTAMP | TIMESTAMP | Not supported | |
| datetime2 | Extended type of datetime, which has a larger data range. By default, the minimum precision is the highest, and the user-defined precision is optional. | TIMESTAMP | TIMESTAMP | Not supported | |
| smalldatetime | The smalldatetime type is similar to the datetime type. The difference is that the smalldatetime type stores data from January 1, 1900 to June 6, 2079. When the date and time precision is low, the smalldatetime type can be used. Data of this type occupies 4-byte storage space. | TIMESTAMP | TIMESTAMP | Not supported | |
| datetimeoffset | A time that uses the 24-hour clock and combined with date and the time zone. | Not supported (string) | TIMESTAMP | Not supported | |
| Multimedia data types (binary) | text | Stores text data. | Not supported (string) | Not supported (string) | Not supported |
| netxt | The function of this type is the same as that of the text type. It is non-Unicode data with variable length. | Not supported (string) | Not supported (string) | Not supported | |
| image | Variable-length binary data used to store pictures, catalog pictures, or paintings. | Not supported (string) | Not supported (string) | Not supported | |
| binary | Binary data with a fixed length of n bytes, where n ranges from 1 to 8,000. | Not supported (string) | Not supported (string) | Not supported | |
| varbinary | Variable-length binary data | Not supported (string) | Not supported (string) | Not supported | |
| Currency data type | money | Stores currency values. | Not supported (string) | Not supported (string) | Not supported |
| smallmoney | Similar to the money type, a currency symbol is prefixed to the input data. For example, the currency symbol of USD is $. | Not supported (string) | Not supported (string) | Not supported | |
| Data type | bit | Bit data type. The value is 0 or 1. The length is 1 byte. A bit value is often used as a logical value to determine whether it is true(1) or false(0). If a non-zero value is entered, the system replaces it with 1. | Not supported | Not supported | Not supported |
| Other data types | rowversion | Each piece of data has a counter. The value of the counter increases when an insert or update operation is performed on a table that contains the rowversion column in the database. | Not supported | Not supported | Not supported |
| uniqueidentifier | A 16-byte globally unique identifier (GUID) is a unique number generated by the SQL Server based on the network adapter address and host CPU clock. Each GUID is a hexadecimal number ranging from 0 to 9 or a to f. | Not supported | Not supported | Not supported | |
| cursor | Cursor data type | Not supported | Not supported | Not supported | |
| sql_variant | Stores any valid SQL Server data except the text, image, and timestamp data, which facilitates the development of the SQL Server. | Not supported | Not supported | Not supported | |
| table | Stores the result set after a table or view is processed. | Not supported | Not supported | Not supported | |
| xml | Data type of the XML data. XML instances can be stored in columns or variables of the XML type. The stored XML instance size cannot exceed 2 GB. | Not supported | Not supported | Not supported |
Data Types Supported in PostgreSQL Database Migration
When the source end is a PostgreSQL database and the destination end is Hive, DLI, or DWS, the following data types are supported:
| Category | Type | Description | Hive | DWS | DLI |
| Character | char | Fixed-length string, which is padded to a specified length with spaces on the right. | CHAR | CHAR | Not supported (string) |
| varchar | Variable-length string. Fields or variables are not padded to the maximum length with spaces. | CARCHAR | CARCHAR | Not supported (string) | |
| Value | smallint | The extension name int2 is stored in two bytes and ranges from –32768 to 32767. | SMALLINT | SMALLINT | SMALLINT |
| int | The extension name int4 is stored in four bytes and ranges from –2147483648 to 2147483647. | INTEGER | INT | INT | |
| bigint | The extension name int8 is stored in eight bytes and ranges from –9223372036854775808 to 9223372036854775807. | BIGINT | BIGINT | BIGINT | |
| decimal(p,s) | The precision p represents the number of valid digits stored in the value, and the scale s represents the number of digits after the decimal point that can be stored. The maximum value of p is 1000. | DECIMAL(P,S) | DECIMAL(P,S) | DECIMAL(P,S) | |
| float | 4-byte or 8-byte storage. float(n): For the single precision, the value of n ranges from 1 to 24, the number of valid precision digits is 6, and the length is four bytes. For the double precision, the value of n ranges from 25 to 53, the number of valid precision digits is 15, and the length is 8 bytes. | FLOAT/DOUBLE | FLOAT/DOUBLE | FLOAT/DOUBLE | |
| smallserial | Sequence data type, which is stored in smallint format | SMALLINT | SMALLINT | SMALLINT | |
| serial | Sequence data type, which is stored in int format | INTEGER | INT | INT | |
| bigserial | Sequence data type, which is stored in bigint format | BIGINT | BIGINT | BIGINT | |
| Time and date | date | Stores the date. | DATE | DATE | DATE |
| timestamp | Stores date and time data without time zones. | TIMESTAMP | TIMESTAMP | Not supported (string) | |
| timestamptz | Stores the date and time, including the time zone. | TIMESTAMP | TIMESTAMPZ | Not supported (string) | |
| time | Time within one day, excluding the time zone | Not supported (string) | TIME | Not supported (string) | |
| timez | Time within one day, including the time zone | Not supported (string) | TIMEZ | Not supported (string) | |
| interval | Time interval | Not supported (string) | Not supported (string) | Not supported (string) | |
| Bit string | bit | Fixed-length string, for example, b'000101' | Not supported (string) | Not supported (string) | Not supported (string) |
| varbit | Variable-length string, for example, b'101' | Not supported (string) | Not supported (string) | Not supported (string) | |
| Currency type | money | The value is stored in eight bytes and ranges from –922337203685477.5808 to 922337203685477.5807. | DOUBLE | MONEY | DECIMAL(P,S) |
| Boolean | boolean | The value is stored in one byte and can be 1, 0, or NULL. | BOOLEAN | BOOLEAN | BOOLEAN |
| Text type | text | Variable-length text without a length limit | Not supported (string) | Not supported (string) | Not supported (string) |
Data Types Supported in DWS Database Migration
If the migration source is a DWS database, the following data types are supported.
| varchar | Variable-length string. Fields or variables are not padded to the maximum length with spaces. | |
| Value | double | Stores double-precision floating-point numbers. |
| decimal(p,s) | The precision p represents the number of valid digits stored in the value, and the scale s represents the number of digits after the decimal point that can be stored. The maximum value of p is 1000. | |
| numeric | Stores zero, positive, and negative fixed point numbers. | |
| real | Same as double | |
| int | int is stored in four bytes, where one binary bit represents a sign bit, and the other 31 binary bits represent a length and a size, and may represent all integers ranging from –231 to 231 – 1. | |
| bigint | bigint is stored in eight bytes, where one binary bit represents a sign bit, and the other 63 binary bits represent a length and a size, and may represent all integers ranging from –263 to 263 – 1. | |
| smallint | Data of the smallint type occupies two bytes of storage space. One binary bit indicates a positive or negative sign of an integer value, and the other 15 binary bits indicate a length and a size, and may represent all integers ranging from –215 to 215. | |
| tinyint | Tinyint data occupies one byte of storage space and can represent all integers ranging from 0 to 255. | |
| timestamp | Stores date and time data without time zones. | |
| time | Time within one day, excluding the time zone | |
Data Types Supported in ShenTong Database Migration
When the source is a ShenTong database and the destination is MRS Hive or MRS Hudi, the following data types are supported.
| Category | Type | Description | Storage Format Example | MRS Hive | MRS Hudi |
| Character | VARCHAR | Stores specified fixed-length character strings. | 'a' or 'aaaaa' | VARCHAR(765) | STRING |
| BPCHAR | Stores specified variable-length character strings. | 'a' or 'aaaaa' | VARCHAR(765) | STRING | |
| Value | NUMERIC | Stores zero, positive, and negative fixed point numbers. | 52.36 | DECIMAL(10, 0) | DECIMAL(18, 0) |
| INT | Stores zero, positive, and negative fixed point numbers. | 5236 | INT | INT | |
| BIGINT | Stores signed integers. Integer part: 19 digits; decimal part: 0 digits | 5236 | BIGINT | BIGINT | |
| TINYINT | Stores signed integers. Integer part: 3 digits; decimal part: 0 digits | 100 | SMALLINT | INT | |
| BINARY | Stores fixed-length binary data. | 0x2A3B4058 | Not supported | FLOAT | |
| VARBINARY | Stores variable-length binary data. | 0x2A3B4058 | Not supported | BINARY | |
| FLOAT | Stores floating-point numbers with binary precision. | 52.36 | FLOAT | FLOAT | |
| DOUBLE | Stores double-precision floating-point numbers. | 52.3 | DOUBLE | DOUBLE | |
| Time and date | DATE | Stores information about the year, month, and day. | '1999-10-01', '1999/10/01', or '1999.10.01' | DATE | DATE |
| TIME | Stores information about the hour, minute, and second. | '09:10:21' or '9:10:21' | STRING | STRING | |
| TIMESTAMP | Stores information about the year, month, day, hour, minute, and second. | '2002-12-12 09:10:21', '2002-12-12 9:10:21', '2002/12/12 09:10:21', or '2002.12.12 09:10:21' | TIMESTAMP | TIMESTAMP | |
| Multimedia | CLOB | Stores variable-length binary large objects with a maximum length of 2 GB minus 1 byte. | 0x5236 (binary data) | STRING | STRING |
| BLOB | Stores variable-length binary large objects with a maximum length of 2 GB minus 1 byte. | 0x5236 (binary data) | Not supported | BINARY | |
| Boolean | BOOLEAN | The value is stored in one byte and can be 1, 0, or NULL. | 1 | BOOLEAN | BOOLEAN |
Data Types Supported in SAP HANA Database Migration
If the source is an SAP HANA database, the following data types are supported.
| NVARCHAR | Variable-length character string contains data in Unicode format. | |
| TEXT | Stores long character strings. The maximum length of a character string is 2 GB minus 1 byte. Long text strings are stored. | |
| Value | BIGINT | Stores signed integers. Integer part: 19 digits; decimal part: 0 digits |
| TINYINT | Stores signed integers. Integer part: 3 digits; decimal part: 0 digits | |
| SMALLINT | Data of the smallint type occupies two bytes of storage space. One binary bit indicates a positive or negative sign of an integer value, and the other 15 binary bits indicate a length and a size, and may represent all integers ranging from –215 to 215. | |
| REAL | The value can be a positive or negative decimal number. | |
| DECIMAL | Numeric data type with fixed precision and scale | |
| FLOAT | Stores floating-point numbers with binary precision. | |
| DOUBLE | Stores double-precision floating-point numbers. | |
| TIME | Stores information about the hour, minute, and second. | |
| TIMESTAMP | Stores information about the year, month, day, hour, minute, and second. | |
| NCLOB | This type can store a maximum of 4 GB data. When the character set is converted, this type is affected. | |
Data Types Supported in DLI Database Migration
If the migration source is a DLI database, the following data types are supported.
| Character | CHAR | Stores specified fixed-length character strings. |
| VARCHAR | Same as CHAR | |
| STRING | Stores long character strings. The maximum length of a character string is 2 GB minus 1 byte. Long text strings are stored. | |
| INT | Stores signed integers. Integer part: 10 digits; decimal part: 0 digits | |
If the migration source is an Elasticsearch/CSS database, the following data types are supported.
| Category | Type | Description | Storage Format Example | MySQL |
| Character | keyword | Stores strings. | "keyword" | String |
| text | Stores long character strings. The maximum length of a character string is 2 GB minus 1 byte. Long text strings are stored. | "long string" | TEXT | |
| string | Stores long character strings. The maximum length of a character string is 2 GB minus 1 byte. Long text strings are stored. | "a string" | String | |
| Integer | short | Stores 16-bit signed integers ranging from –32768 to 32767. | 32765 | smallInt |
| integer | Stores 32-bit signed integers ranging from –231 to 231 – 1. | 3276566 | int | |
| long | Stores 64-bit signed integers ranging from –263 to 263 – 1. | 3276566666 | BIGINT | |
| Value | double | 64-bit IEEE 754 double-precision floating-point format | 21.333 | double |
| float | 32-bit IEEE 754 single-precision floating-point format | 21.333 | double | |
| Boolean | boolean | The value is stored in one byte and can be 1, 0, or NULL. | 1 | Boolean |
| Object | object | A string of flat storage objects | {"users.name":["John","Smith"], users.age":[26,28], "users.gender":[1, 2]} | TEXT |
| Nested | nested | A string of nested storage objects | {"users.name" : "John" , "users.age" : 26, "users.gender" : 1} { "users.name" : "Smith", "users.age" : 28, "users.gender" : 2} | TEXT |
| Date | date | A string in the date format | "2018-01-13" or "2018-01-13 12:10:30" | DATE or timeStamp |
| Special type | ip | A string in the IP address format | "192.168.127.100" | String |
| Array | string_array | An array of strings | ["str","str"] | TEXT |
| short_array | An array of 16-bit integers | [1,1,1] | TEXT | |
| integer_array | An array of 32-bit integers | [1,1,1] | TEXT | |
| long_array | An array of 64-bit integers | [1,1,1] | TEXT | |
| float_array | An array of 32-bit floating-point numbers | [1.0,1.0,1.0] | TEXT | |
| double_array | An array of 64-bit floating-point numbers | [1.0,1.0,1.0] | TEXT | |
| Value range | completion | A string that is automatically completed | "string" | TEXT |
Data Types Supported in Doris Database Migration
If the migration source is a Doris database, the following data types are supported.
| String | CHAR(M) | Range: char[(length)]. A fixed-length string of 1 to 255 characters (1 by default). |
| VARCHAR(M) | Range: char(length). A variable-length string of 1 to 65,535 characters. | |
| Value type | TINYINT | Length: 1-byte signed integer Range: [-128, 127] |
| SMALLINT | Length: 2-byte signed integer Range: [-32768, 32767] | |
| INT | Length: 4-byte signed integer Range: [-2147483648, 2147483647] | |
| BIGINT | Length: 8-byte signed integer Range: [-9223372036854775808, 9223372036854775807] | |
| LARGEINT | Length: 16-byte signed integer Range: [-2^127, 2^127-1] | |
| FLOAT | Length: 4-byte floating point number Range: -3.40E+38 to +3.40E+38 | |
| DOUBLE | Length: 8-byte floating point number Range: -1.79E+308 to +1.79E+308 | |
| DECIMAL[M,D] | Decimal type that ensures precision. M indicates the total number of valid digits, and D indicates the maximum number of digits after the decimal point. The range of M is [1,27], and that of D is [1,9]. In addition, M must be greater than or equal to D. The default value is decimal[10,0]. Precision: 1–27 Scale: 0–9 | |
| Date | DATE | Range: ['1000-01-01', '9999-12-31']. The default printing format is 'YYYY-MM-DD'. |
| DATETIME | Range: ['1000-01-01 00:00:00', '9999-12-31 00:00:00']. The default printing format is 'YYYY-MM-DD HH:MM:SS'. | |
| Special type | HLL | HyperLogLog (HLL) is a binary type. It can be used only for aggregation tables, and the aggregation type must be HLL_UNION. This type is mainly used to pre-aggregate data in non-accurate and fast deduplication scenarios. HLL columns can be queried or used only using hll_union_agg, hll_cardinality, or hll_hash. |
| BITMAP | BITMAP is a binary type. It can be used only for aggregation tables, and the aggregation type must be BITMAP_UNION. This type is mainly used to pre-aggregate data in accurate deduplication scenarios. It can also be used to store user IDs in user profile scenarios. BITMAP columns can be queried or used only using BITMAP functions. |
Data Types Supported in Dameng Database Migration
When the source end is a Dameng database and the destination end is a Hive or DWS database, the following data types are supported.
| Character | CHAR | Stores specified fixed-length character strings. | 'a' or 'aaaaa' | CHAR | CHAR |
| CHARACTER | Same as CHAR | 'a' or 'aaaaa' | CHAR | CHAR | |
| VARCHAR | Stores specified variable-length character strings. | 'a' or 'aaaaa' | VARCHAR | VARCHAR | |
| VARCHAR2 | Same as VARCHAR | 'a' or 'aaaaa' | VARCHAR | VARCHAR | |
| Value | NUMERIC | Stores zero, positive, and negative fixed point numbers. | 52.36 | DECIMAL | NUMERIC |
| DECIMAL | Similar to NUMERIC | 52.36 | DECIMAL | NUMERIC | |
| DEC | Same as DECIMAL | 52.36 | DECIMAL | NUMERIC | |
| INTEGER | Stores signed integers. Integer part: 10 digits; decimal part: 0 digits | 5236 | INT | INTEGER | |
| TINYINT | Stores signed integers. Integer part: 3 digits; decimal part: 0 digits | 100 | TINYINT | SMALLINT | |
| SMALLINT | Stores signed integers. Integer part: 5 digits; decimal part: 0 digits | 9999 | SMALLINT | SMALLINT | |
| BYTE | Similar to TINYINT. Integer part: 3 digits; decimal part: 0 digits | 100 | TINYINT | SMALLINT | |
| BINARY | Stores fixed-length binary data. | 0x2A3B4058 | BINARY (NULL) | BYTEA (NULL) | |
| VARBINARY | Stores variable-length binary data. | 0x2A3B4058 | BINARY (NULL) | BYTEA (NULL) | |
| FLOAT | Stores floating-point numbers with binary precision. | 52.36 | FLOAT | FLOAT8 | |
| DOUBLE | Similar to FLOAT | 52.36 | DOUBLE | FLOAT8 | |
| REAL | Stores binary floating-point numbers. | 52.3 | FLOAT | FLOAT4 | |
| DOUBLE PRECISION | Stores double-precision floating-point numbers. | 52.3 | DOUBLE | FLOAT8 | |
| Bit string | BIT | Stores 1, 0, or NULL. | 1, 0, or NULL | TINYINT(1 0 NULL) | BOOLEAN (true false NULL) |
| Time and date | DATE | Stores information about the year, month, and day. | '1999-10-01', '1999/10/01', or '1999.10.01' | DATE | TIMESTAMP |
| TIME WITH TIME ZONE | Stores a TIME value with a time zone. Add the time zone information to the end of the TIME type. | '09:10:21 +8:00', '09:10:21+8:00', or '9:10:21+8:00' | Not supported (string) | TIME WITH TIME ZONE | |
| TIMESTAMP WITH TIME ZONE | Stores a TIMESTAMP value with a time zone. Add the time zone information to the end of the TIMESTAMP type. | '2002-12-12 09:10:21 +8:00', '2002-12-12 9:10:21 +8:00', '2002/12/12 09:10:21 +8:00', or '2002.12.12 09:10:21 +8:00' | TIMESTAMP | TIMESTAMP WITH TIME ZONE | |
| TIMESTAMP WITH LOCAL TIME ZONE | Stores the TIMESTAMP value of a local time zone. The standard time zone type (TIMESTAMP WITH TIME ZONE) can be converted to the local time zone type. | '2002-12-12 09:10:21 +8:00', '2002-12-12 9:10:21 +8:00', '2002/12/12 09:10:21 +8:00', or '2002.12.12 09:10:21 +8:00' | Not supported (string) | Not supported (TEXT) | |
| DATETIME WITH TIME ZONE | Same as TIMESTAMP WITH TIME ZONE | '2002-12-12 09:10:21 +8:00', '2002-12-12 9:10:21 +8:00', '2002/12/12 09:10:21 +8:00', or '2002.12.12 09:10:21 +8:00' | TIMESTAMP | TIMESTAMP WITH TIME ZONE | |
| INTERVAL YEAR | Interval of years. The leading precision specifies the range of years. | INTERVAL '0015' YEAR | Not supported (string) | Not supported (VARCHAR) | |
| INTERVAL YEAR TO MONTH | Interval of months and years. The leading precision specifies the range of years. | INTERVAL '0015-08' YEAR TO MONTH | Not supported (string) | Not supported (VARCHAR) | |
| INTERVAL MONTH | Interval of months. The leading precision specifies the range of months. | INTERVAL '0015' MONTH | Not supported (string) | Not supported (VARCHAR) | |
| INTERVAL DAY | Interval of days. The leading precision specifies the range of days. | INTERVAL '150' DAY | Not supported (string) | Not supported (VARCHAR) | |
| INTERVAL DAY TO HOUR | Interval of hours and days. The leading precision specifies the range of days. | INTERVAL '9 23' DAY TO HOUR | Not supported (string) | Not supported (VARCHAR) | |
| INTERVAL DAY TO MINUTE | Interval of minutes, hours, and days. The leading precision specifies the range of days. | INTERVAL '09 23:12' DAY TO MINUTE | Not supported (string) | Not supported (VARCHAR) | |
| INTERVAL DAY TO SECOND | Interval of seconds, minutes, hours, and days. The leading precision specifies the range of days. | INTERVAL '09 23:12:01.1' DAY TO SECOND | Not supported (string) | Not supported (VARCHAR) | |
| INTERVAL HOUR | Interval of hours. The leading precision specifies the range of hours. | INTERVAL '150' HOUR | Not supported (string) | Not supported (VARCHAR) | |
| INTERVAL HOUR TO MINUTE | Interval of minutes and hours. The leading precision specifies the range of hours. | INTERVAL '23:12' HOUR TO MINUTE | Not supported (string) | Not supported (VARCHAR) | |
| INTERVAL HOUR TO SECOND | Interval of seconds, minutes, and hours. The leading precision specifies the range of hours. | INTERVAL '23:12:01.1' HOUR TO SECOND | Not supported (string) | Not supported (VARCHAR) | |
| INTERVAL MINUTE | Interval of minutes. The leading precision specifies the range of minutes. | INTERVAL '150' MINUTE | Not supported (string) | Not supported (VARCHAR) | |
| INTERVAL MINUTE TO SECOND | Interval of minutes and seconds. The leading precision specifies the range of minutes. | INTERVAL '12:01.1' MINUTE TO SECOND | Not supported (string) | Not supported (VARCHAR) | |
| INTERVAL SECOND | Interval of seconds. The leading precision specifies the value range of the integer part of the second | INTERVAL '51.1' SECOND | Not supported (string) | Not supported (VARCHAR) | |
| Multimedia | IMAGE | IMAGE specifies the image type in the multimedia information. An image consists of a pixel lattice with a maximum length of 2 GB minus 1 byte. In addition to storing image data, other binary data can also be stored. | 0x2A3B4058 (binary data) | Not supported | Not supported |
| LONGVARBINARY | Same as IMAGE | 0x2A3B4059 (binary data) | Not supported | Not supported | |
| TEXT | Stores the long string type. The maximum length of a string is 2 GB minus 1 byte. | 0x5236 (binary data) | Not supported | Not supported | |
| LONGVARCHAR | Similar to TEXT | 0x5236 (binary data) | Not supported | Not supported | |
| BLOB | Stores variable-length binary large objects with a maximum length of 2 GB minus 1 byte. | 0x5236 (binary data) | Not supported | Not supported | |
| CLOB | Stores variable-length binary large objects with a maximum length of 2 GB minus 1 byte. | 0x5236 (binary data) | Not supported | Not supported | |
| BFILE | Specified the binary files stored in the operating systems. Files are stored in the operating systems instead of the databases. They can be read only. | - | Not supported | Not supported |
