Supported Data Sources (2.9.2.200)
- Table/File migration in the import of data into a data lake or migration of data to the cloud. For details, see Data Sources Supported by Table/File Migration.
- Entire DB migration in the import of data into a data lake or migration of data to the cloud. For details, see Supported Data Sources in Entire DB Migration.
This section describes the data sources supported by CDM clusters of version 2.9.2.200. The supported data sources vary depending on the CDM cluster version.
Table/File migration can migrate data in tables or files.
Category |
Source |
Destination |
Description |
Data warehouse |
GaussDB(DWS) |
The DWS physical machine management mode is not supported. |
Data Lake Insight (DLI) |
You must have the SELECT permission (for querying tables) on all fields of the DLI data source. |
MRS ClickHouse |
Data warehouse: MRS ClickHouse and Data Lake Insight (DLI) |
Hadoop |
MRS HDFS |
MRS HBase |
MRS Hive |
MRS Hudi |
Data warehouse: GaussDB(DWS) |
FusionInsight HDFS |
FusionInsight HBase |
FusionInsight Hive |
Apache HBase |
Apache Hive |
Apache HDFS |
Object storage |
Object Storage Service (OBS) |
File system |
FTP |
SFTP |
HTTP |
Hadoop: MRS HDFS |
Relational database |
RDS for MySQL |
RDS for SQL Server |
RDS for PostgreSQL |
MySQL |
PostgreSQL |
Oracle |
Microsoft SQL Server |
SAP HANA |
SAP HANA data sources have the following restrictions:
Database sharding |
Database shards cannot serve as the destination. A shard link connects to multiple backend data sources at the same time. The link can be used as the job source to migrate data from those data sources to other data sources. |
NoSQL |
Redis |
Hadoop: MRS HDFS, MRS HBase, and MRS Hive |
NoSQL except CloudTable cannot serve as the destination. |
Document Database Service (DDS) |
MongoDB |
CloudTable HBase |
Cassandra |
Message system |
Data Ingestion Service (DIS) |
Search: Cloud Search Service (CSS) |
The message system cannot serve as the destination. |
Apache Kafka |
DMS Kafka |
MRS Kafka |
Search |
Elasticsearch |
Only the non-security mode is supported. |
You are advised to use Logstash to import data to CSS. For details, see Using Logstash to Import Data to Elasticsearch |
In the preceding table, the non-cloud data sources, such as MySQL, include on-premises MySQL, MySQL built on ECSs, or MySQL on the third-party cloud.
Entire DB migration is used when an on-premises data center or a database created on an ECS needs to be synchronized to a database service or big data service on the cloud. It is suitable for offline database migration but not online real-time migration.
Table 2 lists the data sources supporting entire DB migration using CDM.
Category |
Data Source |
Read |
Write |
Description |
Data warehouse |
Data Warehouse Service (DWS) |
Supported |
Supported |
Hadoop (available only for local storage, and not for storage-compute decoupling, Ranger, or ZooKeeper for which SSL is enabled) |
MRS HBase |
Supported |
Supported |
Entire DB migration only to MRS HBase
Recommended versions:
MRS clusters whose Kerberos encryption type is aes256-sha2,aes128-sha2 are not supported, and only MRS clusters whose Kerberos encryption type is aes256-sha1,aes128-sha1 are supported. |
MRS Hive |
Supported |
Supported |
Entire DB migration only to a relational database
2.x versions are not supported. The following versions are recommended:
Supported |
Not supported |
Supported |
Not supported |
Apache HBase |
Supported |
Not supported |
Apache Hive |
Supported |
Not supported |
RDS for MySQL |
Supported |
Supported |
Migration from OLTP to OLTP is not supported. In this scenario, you are advised to use the Data Replication Service (DRS). |
Supported |
Supported |
Supported |
Supported |
MySQL |
Supported |
Not supported |
PostgreSQL |
Supported |
Not supported |
Supported |
Not supported |
Oracle |
Supported |
Not supported |
SAP HANA |
Supported |
Not supported |
Dameng database |
Supported |
Not supported |
Only to DWS and Hive |
NoSQL |
Redis |
Supported |
Supported |
Supported |
Supported |
Only migration between DDS and MRS is supported. |
CloudTable Service (CloudTable) |
Supported |
Supported |
