DDS Link Parameters
The DDS link is used to synchronize data from Document Database Service (DDS) on HUAWEI CLOUD to a big data platform.
When connecting CDM to DDS, configure the parameters as described in Table 1.
- DDS data sources with SSL enabled are not supported.
- Do not change the password or user when a job is running. If you do so, the password will not take effect immediately and the job will fail.
Parameter |
Description |
Example Value |
Name |
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for |
dds_link |
Server List |
List of server addresses. Enter each address in the format of IP address or domain name of the database server:port number, and separate the entered addresses with semicolons (;). |
192.168.0.1:7300;192.168.0.2:7301 |
Database Name |
Name of the DDS database to be connected |
DB_dds |
Username |
Username used for logging in to DDS |
cdm |
Password |
Password used for logging in to DDS |
Is direct connection mode |
This mode applies to the scenario where the network of the primary node is normal but that of the replica node is abnormal.
No |
