Updated on 2026-07-29 GMT+08:00
Viewing Traces
Overview
You can use Cloud Trace Service (CTS) to record key operation events related to CDM. The events can be used in various scenarios such as security analysis, compliance audit, resource management, and problem locating.
After you enable CTS, the system starts to record the CDM operations. The management console of CTS stores the traces of the latest seven days.
CTS has been enabled. For details about how to enable it, see Enabling CTS.
  1. Log in to the management console and choose Cloud Trace Service from the service list.
  2. The trace list is displayed by default. You can filter traces.
    You can select CDM for Trace Source to filter out CDM traces.
    Figure 1 CDM traces
  3. Click on the left of a trace to expand its details.
  4. Click View Trace in the Operation column to view the trace structure details.
    For more information about CTS, see Cloud Trace Service User Guide.
