On this page
Show all
From HTTP
Updated on 2024-11-20 GMT+08:00
If the source link of a job is an HTTP link, configure the source job parameters based on Table 1. Currently, data can only be exported from the HTTP URLs.
Table 1 Parameter description
Example Value
File URL
Use the GET method to obtain data from the HTTP/HTTPS URL.
These connectors are used to read files with an HTTP/HTTPS URL, such as reading public files on the third-party object storage system and web disks.
https://bucket.obs.myhuaweicloud.com/object-key
Pull List File
If this parameter is set to Yes, the system pulls the files corresponding to the URLs in the text file to be uploaded and stores them on OBS. The text file records the file paths on HDFS.
Yes
OBS Link of List File
Select an existing OBS link.
obs_link
OBS Bucket of entries files
Name of the OBS bucket that stores the text file
obs-cdm
Path/Directory of entries files
Custom OBS directories that store the text file. Use slashes (/) to separate different directories.
test1
File Format
Format used for transmitting data. The CSV and JSON formats are supported for migration to tables, and the binary format is supported for file migration.
Binary
Compression Format
Compression format of the source files. The options are as follows:
  • NONE: Files in all formats can be transferred.
  • GZIP: Only files in gzip format can be transferred.
  • ZIP: Only files in Zip format can be transferred.
  • TAR.GZ: Files in TAR.GZ format are transferred.
NONE
Compressed File Suffix
This parameter is displayed when Compression Format is not NONE.
This parameter specifies the extension of the files to be decompressed. The decompression operation is performed only when the file name extension is used in a batch of files. Otherwise, files are transferred in the original format. If you enter * or leave the parameter blank, all files are decompressed.
File Separator
File separator. When multiple files are transferred, CDM uses the file separator to identify files. The default value is |. This parameter is not displayed if Pull List File is set to Yes.
Query Parameter
  • If you set this parameter to Yes, the name of the objects uploaded to OBS does not include the query parameter.
  • If you set this parameter to No, the name of the objects uploaded to OBS includes the query parameter.
No
Disregard Non-existent Path or File
If this is set to Yes, the job can be successfully executed even if the source path does not exist.
No
MD5 File Extension
This parameter is used to check whether the files extracted by CDM are consistent with source files. For details, see MD5 Verification.
.md5
Query Parameter
If this parameter is set to Yes, the name of the object to be uploaded is a string with the query parameter removed.
No
