CDM Metrics
Function
Cloud Eye monitors the running status of cloud services and usage of each metric, and creates alarm rules for monitoring metrics.
After you create a CDM cluster, Cloud Eye automatically associates with CDM monitoring metrics to help you understand the running status of the CDM cluster.
- This section describes the CDM metrics that can be monitored by Cloud Eye as well as their namespaces and dimensions.
- For details about CDM monitoring metrics, see Querying CDM Metrics.
- For details about how to set alarm rules, see Configuring CDM Alarm Rules.
You have obtained required Cloud Eye permissions.
Namespace
SYS.CDM
Metrics
Table 1 lists the CDM metrics.
ID |
Name |
Description |
Value Range |
Unit |
Conversion Rule |
Monitored Object (Dimension) |
Monitoring Period (Raw Data) |
bytes_in |
Bytes In |
Measures the network inbound rate of the monitored object. |
≥ 0 bytes/s |
bytes/s |
1024(IEC) |
Cloud Data Migration |
1 minute |
bytes_out |
Bytes Out |
Measures the network outbound rate of the monitored object. |
≥ 0 bytes/s |
bytes/s |
1024(IEC) |
1 minute |
cpu_usage |
CPU Usage |
Measures the CPU usage of the monitored object. |
0% to 100% |
N/A |
1 minute |
mem_usage |
Memory Usage |
Measures the memory usage of the monitored object. |
0% to 100% |
N/A |
1 minute |
pg_pending_job |
Number of Queued Jobs |
Number of jobs in the PENDING state in the CDM instance.
This metric is available in version 2.10.0.300 and later versions. |
>=0 |
Count |
N/A |
1 minute |
pending_threads |
Maximum Concurrent Extractors |
Number of concurrent extraction threads in the Waiting state in the CDM instance.
>=0 |
Count |
N/A |
1 minute |
disk_usage |
Disk Usage |
Measures the disk usage of the physical server accommodating the monitored ECS, which is not accurate as that obtained on the monitored ECS. |
0.001% to 90% |
N/A |
1 minute |
disk_io |
Disk I/O |
Measures the bytes read from and written to a disk per second on the physical server accommodating the monitored ECS, which is not accurate as those obtained on the monitored ECS. |
≥ 0 byte/s |
byte/s |
1024(IEC) |
1 minute |
tomcat_heap_usage |
Heap Memory Usage |
Measures the heap memory usage of the physical server accommodating the monitored ECS, which is not accurate as that obtained on the monitored ECS. |
0.001% to 90% |
N/A |
1 minute |
tomcat_connect |
Tomcat Concurrent Connections |
Measures the number of Tomcat concurrent connections on the physical server. |
0 to 2,147,483,647 |
Count |
N/A |
1 minute |
tomcat_thread_count |
Tomat Threads |
Measures the number of Tomcat threads on the physical server. |
Count |
N/A |
1 minute |
pg_connect |
Database Connections |
Measures the number of Postgres database connections on the physical server. |
Count |
N/A |
1 minute |
pg_submission_row |
Rows |
Measures the number of rows in the submission table of the Postgres database on the physical server. |
Count |
N/A |
1 minute |
pg_failed_job_rate |
Job Failure Rate |
Measures the job failure rate of the sqoop process on the physical server. |
0.001% to 100% |
N/A |
1 minute |
inodes_usage |
Inodes Usage |
Measures the disk inodes usage of the physical server accommodating the monitored ECS, which is not accurate as that obtained on the monitored ECS. |
0.001% to 100% |
N/A |
1 minute |
Dimension
Key |
Value |
instance_id |
CDM instance |
