Help Center/Cloud Data Migration/User Guide/Key Operation Guide/Migrating Files with Specified Names
Updated on 2024-03-14 GMT+08:00
You can migrate files (a maximum of 50) with specified names from FTP, OBS, or SFTP at a time. The exported files can only be written to the same directory on the migration destination.
When creating a table/file migration job, if the migration source is FTP, OBS, or SFTP, Source Directory/File can contain a maximum of 50 file names, which are separated by vertical bars (|). You can also customize a file separator.
  1. CDM supports incremental file migration (by skipping repeated files), but does not support resumable transfer.
    For example, if three files are to be migrated and the second file fails to be migrated due to the network fault. When the migration task is started again, the first file is skipped. The second file, however, cannot be migrated from the point where the fault occurs, but can only be migrated again.
  2. During file migration, a single task supports millions of files. If there are too many files in the directory to be migrated, you are advised to split the files into different directories and create multiple tasks.
