On this page
Show all
CloudTable Link Parameters
Updated on 2024-10-24 GMT+08:00
When connecting CDM to CloudTable, configure the parameters as described in Table 1.
Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
Table 1 CloudTable link parameters
Example Value
Name
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for
cloudtable_link
ZK Link
Obtain this parameter value from the cluster management page of CloudTable.
cloudtable-cdm-zk1.cloudtable.com:2181,cloudtable-cdm-zk2.cloudtable.com:2181
IAM Authentication
If IAM authentication is enabled for the CloudTable cluster to be connected, set this parameter to Yes. Otherwise, set this to No.
If you select Yes, enter the username, AK, and SK.
No
Username
Username used for accessing the CloudTable cluster
admin
AK
AK for accessing the CloudTable cluster.
You need to create an access key for the current account and obtain an AK/SK pair.
SK
SK for accessing the CloudTable cluster.
Use Cluster Config
You can use the cluster configuration to simplify parameter settings for the Hadoop connection.
No
Cluster Config Name
This parameter is valid only when Use Cluster Config is set to Yes. Select a cluster configuration that has been created.
For details about how to configure a cluster, see Managing Cluster Configurations.
hadoop_01
Click Show Advanced Attributes, and then click Add to add configuration attributes of other clients. The name and value of each attribute must be configured. You can click Delete to delete no longer used attributes.
